10-27-2016 12:16 PM
48 12
tools
  1. Tony Onocaiolo's Avatar
    I realized I've been missing a lot of calls lately and just verified why. My phone is NOT ringing in any setting, but my text messages do make sound still. What could make it do this? Any ideas will be much appreciated. Thanks in advance.
    -Tony
    08-03-2013 11:40 PM
  2. blade22222's Avatar
    Have you tried changing the ring tone? Also you don't have blocking mode on do you?
    Sent from my SCH-I535 using AC Forums mobile app
    08-04-2013 08:12 AM
  3. Tony Onocaiolo's Avatar
    Yes definitely tried changing ring tone. What (and where) is blocking mode? I don't believe it is on because the calls still come through, just there is no noise as if my phone is on silent and it's not.
    08-04-2013 09:27 AM
  4. tytlyf's Avatar
    Have you gone into Settings>MyDevice>Sounds>Volume and make sure the ringer slider is all the way up?
    08-04-2013 09:43 AM
  5. MichaelBR's Avatar
    Blocking Mode blocks calls, sounds etc at specific times of the day.
    Settings / My Device / Blocking Mode
    Sent from my GT-I9505 using AC Forums mobile app
    08-04-2013 11:22 AM
  6. General Tso's Avatar
    Verizon doesn't have blocking mode.
    Sent from my SCH-I545 using Tapatalk 2
    08-04-2013 01:39 PM
  7. blade22222's Avatar
    Wasn't sure if they enabled it with the last update, I'm on the first 4.1.2 update of cleanrom and it was enabled with the rom.
    08-05-2013 06:14 AM
  8. Ashleigh1984's Avatar
    Hi Tony, I had this same problem and I managed to fix mine today because it was driving me crazy...... when you go into settings, and into the sound.... right down the bottom there is an adapt sound function...... I followed that whole process in that right through and my ring tones started working again..... not sure why because I have never touched it before
    Mick Wenzel and Catalin Sorin like this.
    10-06-2013 06:55 AM
  9. lizmary671's Avatar
    The adapt sound worked for me because I had the same problem. My phone started ringing in my hand. I saw it but didn't hear anything. I just got it and thought I broke it already. Thanks Ashleigh1984.
    11-12-2013 08:01 PM
  10. waterman46's Avatar
    I have Samsung SGH-I897, I think this is an older model. I have the same problem where no ringtone is heard but I this model has nothing like "adapt" in the sound or volume or ringtone menus. The last thing in my sound menu, under the feedback category, is Vibration intensity. Help anyone?
    11-13-2013 11:45 PM
  11. Jeanne Brown's Avatar
    Mine does this too! I hate my Samsung Galaxy S4....my messages don't always come through either, and NO I don't have the blocking feature activated. What is causing this?
    Mick Wenzel likes this.
    01-21-2014 12:47 PM
  12. LettrMan's Avatar
    There are various settings for sound. My ringtone was accidentally set to "silent" so was seeing the calls but not hearing them even when i raised the ringtone. fixed it.
    01-28-2014 10:53 AM
  13. jvedder's Avatar
    My wife's Samsung Galaxy S4 is exhibiting a similar problem: It does not ring, but shows a missed call and new voice mail. This happen with the phone sitting next to her keyboard. After picking up the phone and unlocking it, it rings fine with no setting changes. It's almost like the phone is stuck in some audio mode that temporarily mutes the ringer.
    This has happened 4 or 5 times, which makes her appear unresponsive to her clients. Not sure if I should advise her to get a new phone.
    -John
    01-31-2014 08:38 AM
  14. David Carter12's Avatar
    I have a similar problem, but not exactly the same. My Galaxy S4 (on Verizon) "sometimes" does not ring, and other times does. Seems like first call in the morning from certain individuals the phone does not ring (ring tone is on, full blast, no blocking). I get the voicemail message, and when I check my incoming call log, and no call is recorded as incoming. When I check the time of the incoming voicemail and compare it to the call log, it does not show a corresponding incoming call at that time. When I call the person and ask them to call again, the next incoming call from them works fine, rings nice and loud. I just got the phone a couple weeks ago, and returned it for this problem. Tech said it was bad hardware and replaced it. New one is doing the same thing. HELP???
    03-19-2014 09:23 AM
  15. Kurdistan21's Avatar
    Hello, for all Samsung Galaxy users who have problem concerning call sound, that doesn't work.You can easily follow these steps and everything will be done.
    Go to ( settings ------>accessibility---------> Turn off all sounds ( remove the tick). Enjoy call sound ringing !!!!!
    05-01-2014 02:04 AM
  16. bigredgonzo's Avatar
    Verizon branded S4's do most certainly have a Blocking Mode. Settings>My Device tap the switch to turn it on and tap the text to change settings.
    Since there have been a large number of threads online about the Update changing notification settings in some situations, it isn't unreasonable that in some other situations the Blocking feature may have gotten turned on. The absolute worst that can happen is that you waste the 3 seconds that it takes to check it.
    BigRedGonzo
    05-01-2014 09:40 AM
  17. jbl123's Avatar
    I've spent several hours over the past 2 weeks trying to resolve the "no ringtone" issue with my S4. I've tried absolutely everything, and was just about to chalk it up to a Kitkat bug. But then today, I received a spam phone call, and my Call Control software blocked the call like it always does. So I decided to go thru all the settings in the Call Control app. Sure enough -- there's an *experimental* setting to Remove Partial Ringtone. I had forgotten that I had ever turned this on. So I uncheck this, and just like that, the ringtones are now working again!!! Now I need to remember to reset all those other settings I had tried unsuccessfully. And re-install a few apps that I thought might be causing this.
    05-02-2014 11:24 AM
  18. Trisha Sinnott's Avatar
    I have the same problem. Incoming calls are received but no ring tone. But message tone works. Frustrating and have followed all the suggestions on the website to no avail
    05-12-2014 07:01 PM
  19. kingeryck's Avatar
    I was having this same problem. Tried every solution online, nothing. Called Samsung and tried some things. They said I must have an app that's causing the problem and suggested I connect it to my PC, backup all the folders and do a full reset. I didn't do that yet. I started removing apps that I installed around the time this problem started, then checked the Call Control app that blocks restricted numbers and it had an option "Remove partial ring (experimental)" checked. I unchecked it. Now it seems to be fine. So I would say check any utility apps that may mess with your calls, ringtones or volume.
    - - - Updated - - -
    I just literally posted this same reply, not seeing yours.
    05-14-2014 08:43 PM
  20. yoda417's Avatar
    My phone does the same thing and when I try to slide the volume it goes back to silent.
    05-17-2014 12:34 PM
  21. Galaxylizard's Avatar
    I can't find an app that says Call Control - please walk me to this app. Thx
    05-17-2014 05:23 PM
  22. friendlyL's Avatar
    So I came here seeking an answer to my phone not ringing tried all the suggestions and none worked for me, but I kept tryn different things and this is what worked for me go to settings then scroll down to accessibility then scroll down to hearing aids and select it.....my phones ringing was immediately restored
    05-29-2014 07:39 AM
  23. gmkahuna's Avatar
    It was enabled from day one on mine. Not sure what Tso is doing wrong but it is there and it does work.
    06-02-2014 12:41 PM
  24. Jerry Nicholson's Avatar
    My S4 was having the same problem and I was getting really pissed off. I discovered that if you go into Contacts and try adjusting the volume, you'll find that it is all the way down. Turn it up and incoming calls will now ring just fine.
    It would appear that there are TWO volume controls. At least on my phone, if I turn the volume down all the way on the home page, it turns this second mystery volume down as well. If I then turn the volume up all the way on the home page it does NOT turn it up for Contacts. I have to actually go into Contacts and adjust the volume from there.
    06-03-2014 09:07 AM
  25. dewaynef's Avatar
    Remove the battery, wait 5 seconds, replace. I know, seem wacky, but it worked for me.
    06-14-2014 04:16 PM
48 12
  1. Samsung Galaxy Tab 2 7.0: Usb device not recognized.
    By tk91 in forum Samsung Galaxy Tab 2
    Last Post: 12-26-2016, 09:13 PM
  2. Should I swap to a galaxy S4
    By Rigglife in forum Samsung Galaxy S4
    Last Post: 08-06-2013, 09:18 PM
  3. Verizon Galaxy Note 2 in mint condition, tons of extras.
    By fofjjsr in forum Marketplace Archive
    Last Post: 08-05-2013, 11:35 AM
  4. Pics/Videos showing up blank/black in Gallery & won't open
    By seinx in forum AT&T Samsung Galaxy S4
    Last Post: 08-04-2013, 10:53 AM
  5. Galaxy S Relay
    By David Crenshaw in forum T-Mobile Galaxy S III
    Last Post: 08-03-2013, 07:17 PM
