SD Card Problems
jabroneous
I am now on my third S4 and now my SD card does not work. Photos and music cannot be saved onto it. The phone shows some of my old pictures but I am unable to take new ones. I also keep getting an "SD card removed" and "SD Card damaged" message. I never had this problem with my last two phones and take really good care of my stuff so there's no possible way it could be damaged. Anyone else having this problem?
fatboy97
4,820
891
SD Cards do not last forever, and they can fail. You might want to try to get a USB SD Card adaptor... you can insert your SD card into them and then plug that into a USB port on a PC... then check to see if you can read your data off it and possibly recover anything. Then I'd reformat it, using FAT32.
blade22222
548
7
18
+1 on that.
Sent from my SCH-I545 using AC Forums mobile app
GS4Bob
174
If you go to Settings>More>Storage...at the bottom there you can remount the card. It should be fine at least until you reboot.
My att s4 had this issue and it was solved once they pushed an update in early July.
Sent from my GS4 using Tapatalk 4
qxr
55
I exchanged my 1st S4 for this problem. Still happens occasionally but not for minutes at a time while trying to take pictures. Thank goodness costco offers 90 days for refund/exchange.
OhAlfie
872
11
18
I've had the "card damaged" message twice this month and this is how I fixed it.
Sometimes the file system on the card gets corrupted. It can happen for example if the card was ejected while a file operation on it was in progress. When that happens you might have trouble accessing some of the files, loading times for some directories in file explorer may be very slow.
You can attempt to fix it using the desktop windows' built-in chkdsk utility.
Open up command prompt (start->run->cmd.exe) and type
chkdsk /X /F <SD card drive letter>
My SD card reader is X:\ drive, so i would use the following command:
chkdsk /X /F X:
SD card reader is recommended of course
coehlcke
