This is my first phone with 4G. I have no idea if the signal bars on the Verizon Galaxy S4 are telling me about the CDMA vs. LTE signal strength. Can someone clear this up?
Go to Settings/Wireless & Networks/Mobile Networks/Network Type and Strength, which should show you the breakdown of 1x (CDMA) and 4G (LTE) signals.
The bars are simply signal strength. They don't tell you whether you're on CDMA or LTE. There should be an icon at the top near the signal bars that either says 3G or 4G. That's how you know.
It seems that the bars represent whatever the icon in the status bar shows. So if you've got 3 bars and a 4G LTE icon, then that represents LTE strength. It also seems in my experience that LTE strength is a bit lower all around as compared to CDMA.
You can also download and install this app: https://forums.androidcentral.com/e...s/details?id=jp.maruse.cellinf&token=n_vYWxv7
Your "bars" represent the RSSI (signal strength) of whatever technology type you are using at the time. So if you have 4 bars and it says "4G" or "LTE" then the signal is relevant to that. If it says 3G (which is also CDMA) then its relevant to that. Hope that makes sense!
