Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By B. Diddy
    Default Do the signal bars represent CDMA or LTE?
    This is my first phone with 4G. I have no idea if the signal bars on the Verizon Galaxy S4 are telling me about the CDMA vs. LTE signal strength. Can someone clear this up?
  2. #2
    Default Re: Do the signal bars represent CDMA or LTE?
    Go to Settings/Wireless & Networks/Mobile Networks/Network Type and Strength, which should show you the breakdown of 1x (CDMA) and 4G (LTE) signals.
    Scott Kenyon likes this.
  3. #3
    Scott Kenyon's Avatar
    Posts
    Global Posts
    2,189 Global Posts
    Carrier
    MoDaCo Switch Beta 8
    The bars are simply signal strength. They don't tell you whether you're on CDMA or LTE. There should be an icon at the top near the signal bars that either says 3G or 4G. That's how you know.
  4. #4
    Whoops, thanks for the correction, Scott. I was thinking that Verizon was running voice over LTE already, but that isn't until 2014.
  5. #5
    Posts
    Global Posts
    2,189 Global Posts
    Carrier
    Quote Originally Posted by B. Diddy View Post
    This works as well.
  6. #6
    DeerSteak's Avatar
    Posts
    Global Posts
    58 Global Posts
    It seems that the bars represent whatever the icon in the status bar shows. So if you've got 3 bars and a 4G LTE icon, then that represents LTE strength. It also seems in my experience that LTE strength is a bit lower all around as compared to CDMA.
  7. #7
    Quote Originally Posted by Scott Kenyon View Post
    You can also download and install this app: https://play.google.com/store/apps/d...maruse.cellinf
    Your "bars" represent the RSSI (signal strength) of whatever technology type you are using at the time. So if you have 4 bars and it says "4G" or "LTE" then the signal is relevant to that. If it says 3G (which is also CDMA) then its relevant to that. Hope that makes sense!
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by DeerSteak View Post
    Quote Originally Posted by Maria Esponoza View Post
    I guess I'm still not clear even with all the responses. Maria Esponoza said "whatever technology type you are using at the time". When I'm on a phone call, I'm still able to use my mobile data connection to surf the web. So, that means I'm using both technologies simultaneously. So what do the bars really represent? The strength of my call signal, or the strength of my data signal?
  9. #9
    I believe that the bars represent your voice signal. Your data signal is only represented on your notification bar by the 4G or 3G symbol. I know that I've been bumped down to 3G data even with 2-3 bars, so I don't think the bars correlate with data.
  1. Concerned about the Speakers... What's your thoughts
    By Rickgsx in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 09-20-2013, 10:37 AM
  2. The Whole Screen Lights Up when I receive a Text Message
    By ArtistPaula in forum Verizon Samsung Galaxy S4
    Last Post: 09-13-2013, 01:21 AM
  3. where is the google sound search?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-11-2013, 09:38 AM
  4. Can't buy apps on the play store !
    By IIFallenKingII in forum General Help and How To
    Last Post: 09-10-2013, 08:20 PM
  5. Why do apps want so many permissions?
    By wanted198 in forum General News & Discussion
    Last Post: 09-10-2013, 08:18 PM
