1. OregonRob's Avatar
    Hey loyal Android techies...
    Anyone seen or heard any reports of sudden (Like within the last 48 to 96 hours) battery issues with their S4?
    When I got the thing in June it always averaged with regular use for me between 17 and 21 hours on battery... With the same use the last 3 or 4 days I've noticed it lasts like 4 or 5 hours!
    I installed the Landscape Background App last week, so I thought maybe that was it.. Nope... No change.. it died after about 5 hours at work today! >.< (And I don't have my cord with me!!! )
    I went through, disabled most of the junk apps I don't use, hasn't changed the issue at all... Honestly don't know what the heck is going on, but I'm disappointed to say the least, especially if its going to be like that for the next 21 months until I can get an upgrade!
    Other Info: Stock S4 from Verizon... Pretty sure the last I saw it was running 4.2.2...
    09-17-2013 06:03 PM
  2. sstephen17's Avatar
    You might need to refresh the cache for Google Play Services. I've run into battery problems after doing factory resets. Settings > More > Application Manager > All (swipe across) > Google Play Services. Hope this helps.
    09-17-2013 06:47 PM
  3. STSVA's Avatar
    What does the info. in the battery section of the phone's settings menu show as using battery? Anything unusual showing up there?
    09-18-2013 10:41 AM
  4. Maddog241's Avatar
    Yep, yesterday and today especially, horrid battery life. I have not installed or updated or changed anything. When I checked my battery report, Google Services was way over the top. I have rebooted and am charging now. Hopefully that will fix it.
    09-19-2013 04:19 PM
  5. z06psi's Avatar
    I get this from time to time (once a month). I pull the battery and all returns back to normal.
    09-21-2013 09:28 PM
  1. please help >>>wifi / tether issue
    By lordfire00 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 09-25-2013, 08:14 AM
  2. Battery life question
    By Shawbbyz12 in forum Samsung Galaxy S3
    Last Post: 09-21-2013, 07:45 AM
  3. Battery life has gone down hill all of a sudden
    By braxtoq in forum Verizon Galaxy Note 2
    Last Post: 09-19-2013, 08:54 PM
  4. Some issues with my new S4.
    By DaBone82 in forum Samsung Galaxy S4
    Last Post: 09-18-2013, 12:15 PM
  5. DU Battery Saver Pro
    By kanesmith41 in forum Sprint Galaxy Note 2
    Last Post: 09-17-2013, 02:58 PM
