ChuckChurch
Active member
Re: WiFi issues on 4.3
Just curious, how many of you all are running that Verizon anti-virus SW that comes bundled with phone but needs to be activated called 'VZ Protect'? It's made by McAfee. Just on a whim, I turned off the 'Action Scan' called 'Message sent/received'. And turned off the 'Site Advisor' at the bottom. I don't think it's 100% fixed, but it seems better. Anyone else want to give it a try to verify? I've had it off for a couple hours.
Chuck
Chuck
