1. Hghlndr's Avatar
    So all has been purrfect with the fone until these last few days. The Touchwiz request screen to choose between easy and standard home screens, always or once, comes up every 15m! WTH?!
    Not rooted, and using no other launcher. Any thought greatly appreciated. Thanks... peace
    11-17-2013 01:00 AM
  2. CR6's Avatar
    I've never heard of this before. What model phone do you have?
    tap'n
    11-17-2013 01:14 AM
  3. Hghlndr's Avatar
    The problem is out there, though no solutions. Thanks for your input.
    Have verizons galaxy S4 I545.
    11-17-2013 11:28 AM
  4. blade22222's Avatar
    Have you tried rebooting?
    Sent from my SCH-I545 using AC Forums mobile app
    11-17-2013 01:00 PM
  5. STSVA's Avatar
    I'd try this first, and if doesn't work, try a factory reset.
    11-17-2013 02:38 PM
  6. Hghlndr's Avatar
    Thanks everybody for all your comments and assistance; and here's what I have realized: Google Search latest update (3.xx) is the culprit!
    Downgraded to last update, (2.xx) and everything is back to normal with TouchWiz.
    Sad to loose Google latest efforts though!
    11-19-2013 03:33 PM
  7. Belluca's Avatar
    I'm having the same issue now.How did you switch back to the older update?
    11-19-2013 07:59 PM
  8. Hghlndr's Avatar
    BELLUCA: hey, no worries!
    Settings> Application Manager>All> Googles Search> undo updates
    That's it. Restart phone. Peace
    11-20-2013 02:08 AM
  9. Hghlndr's Avatar
    Hey all! Latrst Google search update 3.1.8... 827 is golden. Works without TouchWiz screen showing up. Yes!
    12-11-2013 08:30 PM
  1. Need some help - flashing rom problem
    By Celso74 in forum General Help and How To
    Last Post: 01-31-2016, 10:34 PM
  2. Samsung Galaxy s4 straight talk help. Phone blocked from network use
    By killsburydouboy in forum Samsung Galaxy S4
    Last Post: 03-01-2014, 01:34 PM
  3. Acer Iconia A500 - Won't do a factory data reset...help!
    By markabele in forum Acer Iconia A500
    Last Post: 12-02-2013, 10:16 AM
  4. Samsung Galaxy Note 2 - oops need help
    By sheffsteve1988 in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 11-18-2013, 08:37 PM
  5. FB Issue PLEASE HELP ME
    By Bridget Smith1 in forum Samsung Galaxy S3
    Last Post: 11-17-2013, 02:14 PM
