Results 1 to 8 of 8
    cceller's Avatar
    Posts
    Global Posts
    68 Global Posts
    ROM
    4.0.4 / 4.1.1
    Default S4/Bluetooth in Car/Music - Help
    I don't often listen to music from the phone to the car radio ... but yesterday when I tried it would not work.
    Everything is paired correctly, I even deleted and paired again.
    Samsung Galaxy S4 (VZW) in my 2013 Hyundai Elantra. I have had no issues before now.
    I did get a small update of sorts on 10/29/13 but can remember listening to music via Bluetooth on the phone since (specifically on the way to a family gathering on the Sunday before Veteran's Day).
    I have checked the Bluetooth settings and media is selected.
    Phone via Bluetooth appears to work fine.
    Any suggesitons?
    Thanks!
  2. #2
    Default Re: S4/Bluetooth in Car/Music - Help
    Does your car radio support Bluetooth music? Maybe you had it hard wired previously?
    Set the car radio source to BT AUDIO?
    Sent from my SM-N9005 using Tapatalk 2
    cceller's Avatar
    Posts
    Global Posts
    68 Global Posts
    ROM
    4.0.4 / 4.1.1
    It does support BT, as mentioned I had been listening ....
    I will check the settings on the radio again.
    Thanks.
    cceller's Avatar
    Posts
    Global Posts
    68 Global Posts
    ROM
    4.0.4 / 4.1.1
    Nothing in the radio - has to be some setting I am missing in the phone itself.
  5. #5
    Quote Originally Posted by cceller View Post
    Is it on mute?
  6. #6
    Try in unchecking media audio in your bluetooth systings on your phone when connected to you car. If that doesn't work try deleting the pairing on both the car and the phone and repare your phone
    cceller's Avatar
    Posts
    Global Posts
    68 Global Posts
    ROM
    4.0.4 / 4.1.1
    I gave up - reset the phone - it works fine now - so it was something on the phone and not the radio.
    Thanks.
  8. #8
    Thanks.
    There was an issue with Bluetooth on earlier android systems that required a reset after updating the software. Sounds like yours had that problem.
  1. Worth Rooting T-mobile Samsung Galaxy S4?
    By Missy Ellsworth in forum T-Mobile Samsung Galaxy S4
    Last Post: 12-06-2013, 05:12 PM
  2. Replies: 13
    Last Post: 12-01-2013, 10:48 PM
  3. Asking for some help on a conversion
    By leesumm in forum HTC One Rooting, ROMs & Hacks
    Last Post: 11-28-2013, 01:41 PM
  4. google maps and bluetooth
    By adri80386 in forum Android 4.4 KitKat
    Last Post: 11-27-2013, 09:38 AM
  5. I need help!
    By borizuri in forum Moto X
    Last Post: 11-27-2013, 09:04 AM
B
