Results 1 to 11 of 11
    Default Need Help! Brick? Installed TWRP! Now stuck!
    I am currently stuck. My phone only loads up to "Downloading".
    I was trying to install TWRP Recovery using this page:
    I couldn't get Goo Manager to actually download the file, so I did it manually and then used the dd command in Terminal emulator. Please help!!!!
  2. #2
    wtherrell's Avatar
    Posts
    ROM
    JBSourcery 2.4/ Franco 6
    Default Re: Need Help! Brick? Installed TWRP! Now stuck!
    Quote Originally Posted by phantom27 View Post
    1st things 1st. Is your device MDK? ME7? Or what?
    Sent from my Hyperdriven Dev Edition Vzw SCH-I545 with KT kernel using Tapatalk 4
    It was MJ7
  4. #4
    wtherrell's Avatar
    Posts
    ROM
    It was MJ7
    Ah! There's the problem. You will be lucky to even get root. The bootloader is locked down tight and there is no way around it. It will not allow you to install a custom recovery. Your only hope if rooted would be Safestrap if it becomes available for MJ7. You, my friend, are pretty much SOL.
    How do I even get past the "downloading" screen?
  6. #6
    What do you mean downloading?
    Sent from my SCH-I545 using AC Forums mobile app
    It boots into the screen that has a green android and says "Downloading... Do not turn off target!!"
    At the top it says in really small letters,
    Could not do normal boot.
    ODIN MODE
    PRODUCT NAME: SCH-I545
    CURRENT BINARY: Samsung Official
    SYSTEM STATUS: Custom
    KNOX KERNEL LOCK: 0x0
    KNOX WARRANTY VOID: 0x0
    CSB-CONFIG-LSB: 0X30
    WRITE PROTECTION: Enable
    eMMC BURST MODE enabled
  8. #8
    Looks like you have to flash a stock rom with either kies or odin.
  9. #9
    Posted this link in another thread, but I had the same message. Was freaking out until this worked. Didn't even need to wipe my data.
  10. #10
    Quote Originally Posted by kfres39389 View Post
    Use odin and flash stock VRUEMK2 I'd do the full aka emergency repair. I used this to uninstall safestrap after trying out hyperdrive rom. I'm now completely stock (rooted) MK2. Just be sure to download the correct stock file. If doing the full wipe, don't forget to download the included Pit file. Be sure to Learn how to use odin. odin is your friend
  11. #11
    I found the non wipe.tar worked just fine. If it fails, then wipe the device. Just make sure to backup the system using your computer if possible if you haven't made a backup already.
  1. Transparent notification bar [Now with screenshot]
    By Erick Newman in forum Samsung Galaxy Note 3
    Last Post: 12-07-2013, 05:18 PM
  2. Please help! Bootloops and other problems.
    By Waterdroid in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 12-07-2013, 04:56 AM
  3. Do we have hot spot now?
    By rcmarks314 in forum Verizon HTC Thunderbolt
    Last Post: 12-07-2013, 01:05 AM
  4. external speaker help
    By Tanya Kuchcicki in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-06-2013, 02:59 PM
  5. Replies: 1
    Last Post: 12-06-2013, 02:49 PM
B
