Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By lisaminnie
    Default Galaxy S4 will not connect to home wifi since update
    My GS4 worked great at jumping to wifi spots and at home but now it can't connect AT ALL to my home wifi. Haven't tested it other places i've been before with wifi but pretty sure it will work elsewhere. It will show the wifi connection as "saved, secured" but will only scan again after I push to connect???? I'm not a hundred percent sure this did not start happening with update but my data usage increase (from lack of home wifi) has sure increased since that time. Tried everything; i don't have many options on his home router (Verizon wireless router on WEP). Any ideas anyone?
    Fixed; I called Verizon who told me to delete my home connection from my list of wifi connetions THEN reconnect and it seems to have worked so far.
  2. #2
    Default Re: Galaxy S4 will not connect to home wifi since update
    Welcome to Android Central! Glad you found a solution. If you have further problems, review this guide: [GUIDE] Troubleshooting Wi-Fi Connection Problems
  3. #3
    Hi I'm having the same problem how did you delete the home connection? Thanks
  4. #4
    Go to Settings/Wi-Fi, find your home network, long press it, then select Forget.
  5. #5
    Hi it's not giving me the optoion it's just saying connect when I connect and try and save the password to connect it won't let me the save key is not lit up, any ideas? It's driving me mad thanks
  6. #6
    Turn on wi-fi first. Then, at the Settings/Wi-fi menu, long press the network you want to forget, and the option should appear. You don't see that?
  7. #7
    It's WORKED!!! thank you for your help!!!
    B. Diddy likes this.
  1. HELP!!!! Galaxy S3 wont boot past AT&T Logo
    By SupahBruh in forum Samsung Galaxy S3
    Last Post: 04-01-2014, 06:14 PM
  2. Sprint GS3 Bluetooth Not Working Properly (4.3)
    By lyingfromyou in forum Sprint Galaxy S3
    Last Post: 03-18-2014, 02:03 PM
  3. Moto X Driving Mode Not Working...
    By Mike Hodde in forum Moto X
    Last Post: 12-21-2013, 06:26 PM
  4. How To Load Ringtones On Nexus 5 and quedtion on James Bond.
    By AndroidDario in forum General News & Discussion
    Last Post: 12-18-2013, 01:49 AM
B
