Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By UJ95x
    Default Battery Usage - high
    after 4 hours of occaisional use- I am at 76% battery
    But the alarming thing to me is the following-
    screen 40%
    Google Services 33%
    Android 11%
    These are the main items-
    why is googl services so high? Any way to lower the useage? thoughts?
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Battery Usage - high
    Usually a reboot does the trick
    i have rebooted still doing it
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by sdavid631 View Post
    Download an app called Wakelock Detector from the play Store. It'll tell you what's keeping your phone awake for so long so you can fix the drain
    URGE likes this.
  5. #5
    Check your location settings and whether you have Google settings allowing Google apps to access your location whenever they want. If you do, try disabling that and see if it helps.
    Sent from my SCH-I545 using AC Forums mobile app
  1. Anyone Else Getting Bad Battery after MJ7 update?
    By stanley08 in forum Samsung Galaxy Note 3
    Last Post: 12-28-2013, 12:28 PM
  2. Back/Battery Door Replacement
    By alcor34 in forum Verizon LG G2
    Last Post: 12-22-2013, 09:19 PM
  3. Ok, seriously, my nexus 7 runs out of battery fast
    By wuzao14 in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-14-2013, 01:42 PM
  4. Replies: 17
    Last Post: 12-14-2013, 09:37 AM
  5. is it normal that android system usage is 98%? why?
    By nooneelse in forum HTC One M7
    Last Post: 12-14-2013, 08:01 AM
