I have an S4 with the latest, stock Verizon firmware, over 50% of the time that I record video with the stock camera app, there is no audio recorded, there is an AAC audio stream in the file, but it is silent. Anyone else experiencing this?
Here are the MediaInfo stats on the latest failed recording, the AAC audio is typically encoded at a constant bit rate of 128 Kbps but the failed recordings are encoded at only 4.125 Kbps.
General
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 85.8 MiB
Duration : 1mn 13s
Overall bit rate : 9 747 Kbps
Encoded date : UTC 2014-03-01 19:32:48
Tagged date : UTC 2014-03-01 19:32:48
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=24
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1mn 13s
Source duration : 1mn 13s
Bit rate : 9 808 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.195 fps
Minimum frame rate : 9.609 fps
Maximum frame rate : 240.642 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.440
Stream size : 85.7 MiB (100%)
Source stream size : 85.7 MiB (100%)
Title : VideoHandle
Language : English
mdhd_Duration : 73314
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1mn 13s
Bit rate mode : Constant
Bit rate : 4 125 bps
Nominal bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 37.2 KiB (0%)
Title : SoundHandle
Language : English
General
Format : MPEG-4
Codec ID : isom
Duration : 1mn 13s
Video
Format : AVC
Codec ID : avc1
Duration : 1mn 13s
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Title : VideoHandle
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 13s
Title : SoundHandle
Language : English
