1. Larry Beberdick's Avatar
    I solved tbe battery problem. Turn off auto brightness. Set wifi to not run when screen is off. Manually manage wifi and mobile data switch over.
    03-12-2014 07:25 AM
  2. inkdup102586's Avatar
    That's with auto brightness on among other things
    Sent from my SCH-I545 using Tapatalk
    03-12-2014 08:05 AM
  3. Cwey55's Avatar
    1) How'd you get wifi to not run when the screen is off? and 2) Doesn't this cause some lag when you turn the screen on and want to use something that requires a data connection while the wifi reconnects? (ie. you pop on the screen and want to go right into the browser. Or you try to launch say Facebook from the lock screen even?)
    04-11-2014 10:03 PM
  4. Leo G's Avatar
    I don't use my wifi except for certain few things. Like transferring files. Otherwise I have a plan that is good enough so that I don't get close to using my data limit.
    04-12-2014 03:05 PM
  5. Murph5150's Avatar
    I bought my S4 in July 2013. Since about February 2014 I've noticed a sharp decline in charge longevity. I am utilizing every trick in the book to conserve battery life. If I didn't have a Mophie Juice Pack, I wouldn't make it through the day. This is a key reason I will not purchase a phone with a non removable battery.
    04-12-2014 11:52 PM
  6. Cwey55's Avatar
    I'm in the same boat and approx. timeline. Bought the spare battery kit (Spare battery, external battery charger, and cord) and couldn't be happier.
    I still implement a lot of battery saving measures to make it through the day before switching batteries in the evening but it still works better than tying my phone to the wall in the evening.
    04-13-2014 01:27 PM
  1. LG G Flex: Battery life thread
    By Topgonzo in forum LG G Flex
    Last Post: 10-29-2016, 03:12 PM
  2. Battery issues, possibly since update?
    By ao7415 in forum Android 4.4 KitKat
    Last Post: 11-04-2014, 02:20 AM
  3. I need help with my Sprint Galaxy S3 battery life
    By Janey Tran in forum Sprint Galaxy S III
    Last Post: 03-12-2014, 06:13 PM
  4. Insane battery drain while device locked
    By aeronium in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-12-2014, 04:31 PM
  5. GS4 Message app - group messages out of order
    By sstephen17 in forum Verizon Samsung Galaxy S4
    Last Post: 03-11-2014, 05:56 PM
