Results 1 to 3 of 3
    steph_wilkes73's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery Draining
    I just bought the Galaxy S4 a week a go after having the iPhone 4S. Since then my battery has gone down significantly within a short amount of time. For example after charging my phone all night it will be at 80% within an hour of taking it off of the charger. I did add an app, Battery Doctor, which initially made a significant difference until yesterday. And I am not on my phone constantly either. Any ideas or suggestions would be appreciated.
  2. #2
    inkdup102586's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Re: Battery Draining
    Battery may just be bad. My battery last all day.
    Sent from my SCH-I545 using Tapatalk
  3. #3
    STSVA's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Take a look at Settings - More - Battery and post the %s for the things using your battery. It should be "screen" followed by other stuff; if something is using more than screen, that may be the culprit for excess battery use.
  1. Moto G Overheating and Excessive Battery Consumption
    By Harish Krishnan in forum Moto G (2013)
    Last Post: 10-05-2016, 05:22 AM
  2. HTC One Max: Battery issues
    By jayp1306 in forum HTC One Max
    Last Post: 04-05-2014, 12:36 AM
  3. How much should Android system be taking up in battery life?
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 03-25-2014, 02:57 PM
  4. Android System..Android Os.. battery %
    By RichardHewlett in forum Samsung Galaxy S4
    Last Post: 03-23-2014, 08:16 PM
  5. Nexus 7: Kernel android os using battery when locked
    By Gauhar Mahmood Azeem in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-23-2014, 02:53 PM
