Results 1 to 4 of 4
    Default Bricked this viewsonic g need some help
    This view sonic worked completely fine until the kids left it turned on and killed the battery. It was stuck at the 3 birds screen. I was able to access the recovery screen and tried to do a factory restore. It is now completely stuck at the 3 birds screen and will not enter recovery mode (power plus + volume). I was able to connect it to my computer using a usb cord and found a driver to get it to enter APX mode (Power plus - volume). Tablet shows as a APX device under printers in my windows 7 computer. I am completely stuck now concerning what I do to get the computer to see the tablet so I can access the root directory (not sure if that is right but I hope you get the idea of what I am trying to do) I have an external SD card and not sure if that is what I use to get the tablet to boot correctly. ANY help is appreciated.
  2. #2
    Default Re: Bricked this viewsonic g need some help
    Power off the unit.
    ****DO THIS AT YOUR OWN RISK. THERE IS A POSSIBILITY THAT YOU CAN DAMAGE THE COVER DOING THIS! ****
    Take out the four screws under the rubber caps on the under side of the G-Tab.
    Then pop the case apart carefully....
    Near the center of the curcuit board that you exposed there is a RESET button.
    Press it with the Power off you should then see the screen come to life and boot normally.
    Good Luck ....
    I will try that and let you know, thanks.
    Ok so I tried that and it is still stuck at the 3 birds screen and will not do anything else, could you suggest another method to try?
  1. Really need some help with this!!!-Phone unusable
    By zjaksn10 in forum HTC EVO 4G LTE Rooting, ROMs, and Hacks
    Last Post: 10-21-2012, 10:20 PM
  2. Need some help, partial bricking.
    By igotsanevo4g in forum T-Mobile Nexus S Rooting, ROMs, and Hacks
    Last Post: 05-20-2011, 09:50 PM
  3. Phone pseudo bricked - really need some help (hopefully from thefredelement)
    By hgelpke in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-31-2011, 05:05 PM
  4. Need some help finding this wallpaper
    By chrisdazzo in forum Wallpapers, Ringtones, and Themes
    Last Post: 02-08-2010, 04:48 PM
  5. New Hero needs some help.
    By wolfhound89 in forum HTC Hero
    Last Post: 11-21-2009, 05:04 PM
