My task manager won't start up it says unfortunatelystops and yet its still installed.. even when I delete it an instal another task manager it says the same thing..
Sent from my HTCEVOV4G using Android Central Forums
Printable View
And mms doesn't even work with any sense roms wtf
Stop using a task killer. Android handles tasks fine. Continuing to try and use one will result in missed texts, alarms that don't go off and overall unstableness.
Sent from my HTC Evo V 4G
You're using the wrong roms if MMS breaks. Virgin and Sprint roms are NOT INTERCHANGEABLE.Quote:
Originally Posted by ssiebor14 [Only registered and activated users can see links. Click Here To Register...]
I'm Using a sprint Rom with no task killer .. and mms works fine. Soooooooooo yeah wrong
Keep the discussion civil and on topic. Calling another member a troll is considered trolling.
Thread has been cleaned up.
Sent from my SGSIII
