DO NOT FACTORY RESET THROUGH SYSTEM SETTINGS! this is what BRICKED my phone! always make a nandroid backup and reset through recovery!!
Consider this thread closed until there is a fix available (highly unlikely)
Edit:thanks for the help so far. I think my best chance is flashing the stock rom (if I can find it) or waiting until there is a custom rom out like CM7
Basically, my slider is stuck in recovery and will not boot to android. i had installed the clockworkmod recovery i found in this section for the slider. after installing i did a nandroid backup. i was messing around with my slider for quite a bit, decided to just erase everything and start fresh.
i erased the cache, and performed a factory reset through the recovery. after restoring my backup, my phone keeps booting into the recovery. it wont boot to android at all. it is rooted too.
i don't understand, what happened? is there a solution that can fix this? any help is definitely appreciated. it's gonna suck to find out i may have just wasted $200..
