Battery life is horrid!
thexxoffspring
378
15
The battery life on this phone is so awful. I think it's so much worse than the OV use to be. Listening to pandora for a half hour in the morning causes me to lose 15% battery. That's insane. Is there anyway I can improve my battery life?
Its your data use consumtion. Learn to turn it off while not using it and it should last you a good day and a half. If your not a heavy user.
Sent from my LG-VM701 using Tapatalk
Try installing the Gelato ROM and the GingerKernel v07.1 from this forum to see if that might improve your battery life.
i have to agree that this device eats battery faster than the OV, but it should as it is the same specs with a faster processor and a KB to power. I have not noticed it as badly as yu though. Make sure that you give the phone 3-5 days to get some good battery stats going before you pass jusdgement.
i did go to the gelato rom myself butt I did it for more memoey - cant really comment on battery life just yet as I switched just a few days ago.
I will say that I can get thru a day with moderate use, but it is cutting it close. By around 8 PM i have the old 15% plug in your device warning.
I do have my gmail on push (cant change that I think), my email on hourly, and my rss reader on eery 4 hours - so that may be draining me some.
I do shut off 3g and I have both of those installed. No difference really
The default governor on these phones is set to performance, which means it runs at 800mhz constantly with no scaling. You need to root, install no-frills cpu control or setcpu, and change the governor to on-demand. It's a pretty serious bug to ship a phone with, easily fixed though.
no joke broskis
root
get setcpu
set governer to "on demand" from "performance"
i swear my battery last longer than a nokia....
read this - deffinately shood be stickied!
This is what I did, in order:
1. Charged up stock phone while OFF, removed batterystats, ran phone down until it completely turned itself off. I then charged up the phone, still OFF. The next day, I got 18 hours of battery life, and did for many days after!
2. I then got SetCPU installed. I set the default governer to "ondemand" with minimum at the lower it could go and the maximum at 800Mhz. No profiles were set, nothing else. That day I got close to 23 hours of use, next day I got 30 hours. No reseting of battery stats; I changed nothing else. Phone seemed to work fine, except that I did notice that a few times the phone took a bit longer to wake up from sleep; up to 8 seconds one time. So that got me tweaking around with profiles.
3. I then adjusted SetCPU by setting the default governer still at "ondemand", max=800 mhz min=196 mhz, then enabled profiles. I have two profiles set now: Screen Off which is ondemand max=480 mhz, min=196, and In Call, which is performance max=800 min=800 (I don't think the max/min settings on performance actually matter). I haven't run my phone down completely, but I am getting about 40 hours when I still have about 10% left on my battery at the end of the day. The wake on sleep issue still happens, but it's less than 4 seconds when it does, and the performance when I'm interacting with it is just as zippy as it was when it was set to performance.
I haven't had a desire to tweak with it further - it seems to perform just great now, and getting almost 2 full days worth of battery life is good enough for me.
gugino
