[ROM][REPO]{RGH135} {VM701}{LG55C} CyanogenMod7
[Only registered and activated users can see links. Click Here To Register...]
Honestly, when I flashed all of them, they just kept me in the bootloop, and one of them was ICE CREAM SANDWICH. Everything in that forum belongs to rhg135 of SDX-Developers.
There's also stuff for the LG55C. Let's make CyanogenMod possible!!!!
Re: So I found something a little interesting...
Link says forbidden, can you post the stuff here?
CM7 actually boots for me but I get no service... either way to me its awesome to finally see CM booting up on my Slider instead of like my friends V or my brothers phone ^.^
yeah lemme see what i can do
which one did you flash?
The one under Current Release... I downloaded and flashed the latest one he had for the Slider...Though I was a little confused on the Wipe Data and Cache in his instructions (I did a data factory reset and wiped the cache...but no dalvik cache clearing...wich is making me wonder now if maybe I shouldov tried it..)
which file exactly?
update-cm-7.2.0-RC1-LG-VM701-rhg135-20120413-signed
2012/04/13 12:32:48 61mb
is the file name, date and time.. once my battery charges up I will probably try wiping my dalvik cache as well when I try again to see what happens
Tried it again with dalvik cache wiped still no service...also FYI if anyone else decides to try CM7 they might notice the power button is buggy and might have to press it a few time to get it to do what you want it to...and if you try the dialer it lags a bit also but eh *shrugs* its finally here in some shape/form ... :)
Re: [ROM][REPO]{RGH135} {VM701}{LG55C} CyanogenMod7
if anyone knows how to get the data/wifi working that would be great.
I ported this to the Q... working on the Radio in it. The issues I've found are in the services.jar, the accounts&sync.apk, the radio and the accelerometer. Its anything but an RC but its a very good early alpha. I hope you all get this going. In the meantime I'm going to try to get the radio working... the baseband is nulled.
did you find the optimus q roms in the folder?
Yeah I found them after I posted that. They have the same issues as what I ported to the Q from the VM 701 slider roms. I can get the radio working I think, but I'm having issues with ADB. Someone needs to adb pull the radio.img from their device. I'm not sure if its mtdblock5 thats the radio.img or not, but I keep getting an I/O error when I try to pull it. I tried going through the audio libs because sounds not working. I'm not sure if its his kernel causing the issues or the source from lg. I keep trying to get in touch with him for his repo URL's... but no response yet. We will get CM7 working lol believe me. I just need more info from him...and i really need the radio.img.
Don't know if you all noticed it but the services.jar isn't working for power management either. For me this means the phone will not charge nor wake from being asleep... It's driving me nuts. If I can get his repos I or someone else from Area51 will recompile them and try to work more of the vendor stuff in.
Also see if this doesnt work out for you:
repo init -u git://github.com/rhg/android.git -b gingerbread; . build/envsetup.sh; lunch cyanogen_gelato_VM701-eng; make bacon
wifi works for me. wiped data, cache and dalvik. no service, but I have wifi. my slider isn't activated anyway.
phone doesn't wake from being asleep, like you said. touch screen drivers are iffy. no camera. willing to test anything, and I mean anything. this slider just sits on my desk as it is anyway.
edit: phone will wake from sleep, but not reliably. screen will turn on (you can see it light up), but nothing comes on it. I've got it charging, or at least it says it is. No idea if it actually is.
Okay... little update. I've fixed the VM branding and I've fixed the wake/sleep issues. However the screen on animations not working at least it will wake from being asleep. I'm still working on the radio. We'll see... I really want to get this working... grrrrrr
i have full faith in you jcole20. is it entirely possible the radio.img would be a bit similar to the one in the gelato rom or even stock?
In theory if I can pull the radio.img I can flash it on top of the CM7 build and it will have a working Radio. I've been trying to dd it but I think I need to dump_image to pull it. Thats not the only issue though, and it may be something inside the /system/lib's or /system/etc folder I don't know. I've never fixed a radio issue. But the other big issue is with the Sound. We have absolutely no sound in the rom. That needs to be corrected as well. I've worked hard and I've got a bootable build with some theme engine themes, and the market implemented. But accounts&sync seems to be an issue as well. I don't know if its because of the baseband being nulled or not, but it's not letting me put in account info on wifi. Lol, this is ridiculously frustrating. Here's the link to my current state at the moment. You can flash this on your slider the keymapping will just be different, but go ahead and check the wake/sleep and tell me if its working for you all.
Again this is for the Q but it will boot on the Slider... our kernel base is the same. Your keymapping will just be off. If I get the Radio and all figured out I'll get it working on the Slider builds as well. This is so aggravating.
Edit: The radio is going to not change at all from stock to CM7... it can't change. Thats the issue here, the radio configuration somewhere is either not activating or its not the same. And I really don't have any experience activating a radio. I'm doing as much research as I can trying to figure this out.
Well there are lib files that control the radio too. I've tried figuring out what those are and pushing them in, and still no radio... this is getting to be ridiculous.
