Hi,
Have my Optimus slider and have having a few issues with it, I cant seem to find anyone to help me.
I rooted my phone sometime ago just to remove some of the stock bloatware on the phone, haven't changed the ROM or anything else. I cannot remember if I did a proper back up when I rooted it.
Issues;
Phone doesn't power off when I try to turn it off. It simply reboots. When I press the power button, I get the screen asking me if I want to "Power off", I choose the option to power it off, your phone will shut down, I push "OK" I get the virgin mobile sound and display and vibrate, then I get the logo again and the phone comes right back on. I have removed the battery, I have rebooted it properly by pressing the buttons and getting the reboot menu. Still have issue.
Several times a day my apps will crash, I get the pop up that says it has stopped unexpectedly would you like to force close or report, I click on report and it then says that play store has stopped unexpectedly.
I think my best bet is to un-root, and put my phone back to stock. however don't know exactly how to do that. Can someone here walk me through the unrooting process. I say in the youtube video to use gingerbreak, however cannot find were to get it and if there is a better / easier way to unroot.
Please Help.
Thank You so Much.
Issues;
Please Help.
Thank You so Much.
