Results 1 to 3 of 3
    Default Kakao talk help...
    I have been using Kakao talk on my rooted Optimus V for a while.
    But, It isn't working from last week. I tried reroot and format the SD card and reinstall couple of times.
    Ye..it's working after reinstall but, it stop to work after turn it off and on.
    It just shows "please wait" and go back to the main screen.
    Is there anyone has this problem?
    please advise...
  2. #2
    Default Re: Kakao talk help...
    my kakaotalk doesnot work...
  3. #3
    AndyOpie150's Avatar
    Posts
    ROM
    MiRaGe ROM
    A lot of times when apps stop working properly it's right after an update, which seems to be the problem here.
    To prevent this from happening in the future try downloading AppTyrant if not rooted, and Root Uninstaller if rooted (same developer).
    What they do is save all installed apk's to the sd card. All of them.
    This means if you get an update that is borked you can go back and install the old working version. Problem solved.
    This continues to work time and again for me.
    Note: You don't need the paid version. If you need to re-install an older apk just go to folder on sd card and copy apk to the root of the sd card, then select to install.
