Results 1 to 4 of 4
    Default Which unlocked phones work for virgin mobile
    Looking to upgrade from optimus v. Looked up the triumph but other phones seem better and cheaper. But do all unlocked phones work or certain networks?
    Virgin mobile is working with sprint. So will verizon work or does it have to be virgin mobile or sprint phones? Or any unlocked phone. I have t v with 1200 minutes, and unlimited txt, web, data
    Sent from my VM670 using Tapatalk
  2. #2
    Default Re: Which unlocked phones work for virgin mobile
    only virgin mobile phones work with virgin mobile.
    you can call customer support and tell them you want to use another carriers phone with their service.
    if your extremely lucky they will ask you for that phones mied and you can do it.
    but most likely they will laugh at you and ask you to buy a VMusa phone or gtfo.
    i think MetroPCS will flash verizon and sprint phones to their network, try them.
  3. #3
    kwknott's Avatar
    Posts
    Carrier
    Backside... MiRaGe
    You prob won't have any lucky having them activate another carrier's phone. My sister tried activating a Sprint phone and they wouldn't do it. Also a Verizon phone would have to be flashed so the radio would recognize the Sprint network instead of the Verizon network.
  4. #4
    LeslieAnn's Avatar
    AC Forums Android Developer
    Posts
    Carrier
    Harmonia 3
    VM doesn't allow outside phones on their network, the one method that works puts you in violation of cloning laws. Discussion of this gets people getting banned on on most forum. Bottom line, you can't legally use any other phones.
