1. I3ig Al's Avatar
    I dunno what changed but between last night and today my 3G decided to go poof on me. all system widgets and settings say it is enabled but theres no icon on the status bar and when I disable wifi nothing connects.
    I am writing down everything I have installed since my nandroid is a little stale but I just wanted to ask for any suggestions here before I give up and reflash again.
    Oh, I am running Harmonia 2.03
    EDIT: Cancel that -.- it started working again like 10min after posting.
    01-24-2012 09:59 AM
  2. bmwkeith's Avatar
    I had the same thing happen for a couple of hours this morning with no 3g or icon. It just started working again.
    01-24-2012 10:50 AM
  3. Eollie's Avatar
    Its called service outages. They happen from time to time.
    01-24-2012 11:31 AM
  4. kwknott's Avatar
    Mine was down about 2 hours today
    01-24-2012 02:24 PM
  5. kcls's Avatar
    Ah, that would explain some things! I was like, "I had 3G here 5 minutes ago, why isn't it here now?"
    01-24-2012 06:05 PM
  6. cotylee1991's Avatar
    Virgin Mobile had a 3G service outage within the past 4 days off an on. I was frustrated about the issue also, so I tweeted @VMUsa asking about the issue and they confirmed the 3G outage. They said its fixed now. So remove your battery for 30 seconds, replace it, and boot up, and your good to go!
    Sent from my LG Optimus V.
    IHO BACKside CM7.2
    "Cracker for fun, hacker for LIFE!"
    ThaMth likes this.
    01-24-2012 08:03 PM
  7. ThaMth's Avatar
    Thanks, I hope that's all this is!
    05-18-2013 04:07 PM
