- Aug 2, 2011
- 1,590
- 202
- 0
I need a SD card mounter replacement for the Optimus V, and I don't know where to find one. Any help is Appreciated.
I don't think you understand. My Phone can't read the SD card. The SD mounter is broken. So I can't do anything with the SD card on the phone at all.they are 99 cents and cheaper on ebay
also, you can plug the phone directly into a PC with the included usb cable and browse the sd card that way too.
I might have one for you. My wife ran over her old ov, and I'm pretty sure the screen is the only thing that broke, when I get home I will take a look at it for you
That would make my day, thank's alot.
I don't think you understand. My Phone can't read the SD card. The SD mounter is broken. So I can't do anything with the SD card on the phone at all.![]()
ohhhh by "sd mounter" I assumed the adapter to mount it in a full size SD slot.
as for the slot inside the phone i do believe its soldered to the motherboard.
Honestly, your best bet is find a used, working phone on Craigslist.
If you do find the part, it will be $10, however, I can't locate one. Then you still have to mount it to the board without frying anything. Unless you have some good skills and soldering equipment, it won't work. If you could find a board for cheap, you could just swap that, but I can't even find those, and even that would be $35 or more.
Just grab a used phone one on sale.
Or say screw your sdcard and try to live without one... even tho that seems impossible.
Soldering!!! That sounds fun. I haven't figured out how to take the whole phone apart yet tho, not that I have any problems, but I like taking stuff apart. This is unrelated to curiousnoobs problem, but once you take the screws out of the back, how does it come apart, it seems like it snaps in place or something.
