Results 1 to 11 of 11
- 04-30-2012, 02:01 AM
Thread Author #1
Signal problems
Ok I am having a issue that I can't figure out. My phone will go from 2 bars which I average then drop down two one. I have flashed my prl to sprint but even went back to virgin mobiles prl and it does the same thing. Anyone have any idea how to fix this?
Sent from my LG-VM670 using Tapatalk - 04-30-2012, 02:11 AM #2
Did you flash the update? And do you have good coverage in your area?
I sometimes get 2 bars that go to zero then 1x too.
Sent from my LG-VM670 using Tapatalk 2 Beta-5 - 04-30-2012, 02:24 AM
Thread Author #3
- 04-30-2012, 02:30 AM #4
- 04-30-2012, 02:34 AM
Thread Author #5
- 04-30-2012, 02:46 AM #6
- 04-30-2012, 02:47 AM #7
- 04-30-2012, 02:52 AM
Thread Author #8
- 04-30-2012, 03:06 AM #9
I have good coverage outside of my house, and yet my signal drops often. My old Optimus + Radio update had no signal reboots.
What PRL are you using? I use 00115 I believe.
Sent from my LG-VM670 using Tapatalk 2 Beta-5 - 04-30-2012, 05:14 AM #10
- 04-30-2012, 07:59 AM #11
Reply
