Results 1 to 11 of 11
- 05-16-2012, 07:40 PM
Thread Author #1
Please help!!!!!
So I got a new optimus v and tried to flash a custom recovery i installed it using flash image GUI my phone turns on nd gets past the boot logo but its black is there anyway to fix it or am I f'd over
Sent from my VM670 using Xparent ICS Blue Tapatalk 2Men are only as good as their technical development allows them to be.-George Orwell - 05-16-2012, 07:46 PM #2
- 05-16-2012, 07:55 PM #3
Re: Please help!!!!!
Well im hoping you rooted your phone first, and made a backup because every tutorial to flash a custom rom has always had "Make a backup" But if you did both of these Power down your phone then
hold Home + Volume down , then the power button (all at the same time).
Clear cacha part, clear dalvik cache, format boot, data, system, cache
Then flash your backup
Reboot - 05-16-2012, 08:16 PM #4
- 05-16-2012, 10:58 PM
Thread Author #5
Guys I did root however the recovery is black the screen is black can't see nun
Sent from my VM670 using Xparent ICS Blue Tapatalk 2Men are only as good as their technical development allows them to be.-George Orwell - 05-16-2012, 11:09 PM #6
- 05-16-2012, 11:54 PM
Thread Author #7
Thanks I'll try that tommorow as I left the phone at work
Sent from my VM670 using Xparent ICS Blue Tapatalk 2Men are only as good as their technical development allows them to be.-George Orwell - 05-17-2012, 05:02 AM #8
Sounds like you had a bad flash on your recovery or you used an older recovery that is not compatible with newer ov's. Can you still boot into your rom (android). If so go to this thread http://forums.androidcentral.com/sho....php?p=1150713and download the recovery listed in the "Install Custom Recovery Image" section and flash it with flashimagegui
Sent from my Optimus V running BACKside IHO using Tapatalk2 - 05-17-2012, 12:54 PM
Thread Author #9
That's what I did and my screen went black cant boot into from everything is black
Sent from my VM670 using Xparent ICS Blue Tapatalk 2Men are only as good as their technical development allows them to be.-George Orwell - 05-17-2012, 01:38 PM #10
- 05-17-2012, 04:13 PM
Thread Author #11
Its both the rom and recovery
Reply
