1. Frank999's Avatar
    I don't know what happen but after having my VM Optimus for over a year all of a sudden my wifi went kaput. In the settings>wireless and network settings the turn on wifi box is always unchecked. I'll tap it to check it. I then tap Wi-Fi settings. Before there was always a list of networks that I've either previously connected to. Now they've all mysteriously disappeared. The phone will try to scan for networks but after awhile a message will appear unable to scan for networks. The phone is stock version (no rooting, roms, whatever) with Froyo 2.2.2
    06-23-2012 01:18 PM
  2. droidmyme's Avatar
    Try downloading a WiFi app from Play?
    Sorry I can't help more :P
    06-25-2012 11:08 PM
  3. Frank999's Avatar
    Thanks for response. I did dl wifi analyzer. The graph is completely blank. It's not showing my home router that I'm sitting right in front of nor any of my neighbors' wifi.
    06-26-2012 03:53 PM
  4. kalaniboy's Avatar
    Have you tried a factory reset?
    Sent from my LG-VM670
    06-26-2012 04:30 PM
  5. droidmyme's Avatar
    Hmm. Idk what to say honestly. Did you buy your OV retail? I would actually try calling customer service on this one. Since you're running the stock setup, they may be able to help you troubleshoot the issue.
    Good luck!
    tachikara likes this.
    06-26-2012 05:08 PM
  6. Gtnunit's Avatar
    Download "Fxr Wifi fix and rescue" from the market it saved my optimus when i mysterious lost Wifi connection for no reason
    droidmyme likes this.
    06-27-2012 05:14 PM
  7. Frank999's Avatar
    Thanks to those who responded.
    Droidmyme, the phone was purchased new directly fro VM.
    Kalaniboy, does a factory reset mean I'll lose everything such as settings, bookmarks, my current position in Angry Birds, etc?
    Gtnunit, I did download and try Fxr Wifi with no success.
    06-30-2012 02:25 PM
  8. Zhara's Avatar
    Yes, with a factory reset it will delete all your data and put it back to the way it was straight out of the box. I agree that you should call customer service, but they will most likely have you do a factory reset right off the bat.
    06-30-2012 02:36 PM
  9. bjzapp's Avatar
    Indeed they will, unfortunately. Im sure by now you've done the hole "pull the battery" for like 5minutes by now as well.....
    Good luck.
    Hell, you may get a replacement if unsuccessful
    07-01-2012 10:41 AM
  10. claireHere's Avatar
    hello, i have a problem with my wifi connection on my galaxy k phone. i was browsing the net when the battery went empty.
    i replaced the battery and turned my phone on again. But i wasn't able to use the wifi anymore,it automatically turned off in seconds after i have it turned on,and no more previous wifi spots displayed below. what is wrong with my cellphone?please help how to fix the wifi issue. aside from the wifi problem.everything is okay with my phone.thank you. claire
    Siew Keat Chin likes this.
    12-14-2012 05:49 PM
  11. claireHere's Avatar
    12-14-2012 05:50 PM
  12. claireHere's Avatar
    my problem too
    12-14-2012 05:52 PM
  13. Jane Tully's Avatar
    Same problem - in the end I jammed my finger onto the on/off button for about fifteen seconds, and it worked. The WiFi button woke up, problem solved. It is what we do with our PCs, no? So why not tablets. Anyway, it works. Desperation over.
    12-08-2013 10:40 AM
  14. amanahatan's Avatar
    to solve,use ethernet disconnected
    01-22-2014 09:38 PM
  15. Diane Allen1's Avatar
    how do I do that
    01-23-2014 09:07 PM
  16. AndyOpie150's Avatar
    FYI:
    Delete your current network from the phone. Turn WiFi off, then turn phone off. Turn router off then unplug. Wait 5 minutes, then turn on router (let it fully boot up). Now try to turn WiFi on and sign into network
    This will work to straighten out router, if the router is the culprit. Then if still having problems, at least you know it's not the router for sure.
    01-24-2014 04:06 AM
  17. Rizzababe's Avatar
    are u out of ur mind? how cud i download or even open my play if i cant even turn on my wifi????????
    Nikhil Yalamanchi likes this.
    02-16-2014 05:55 PM
  18. AndyOpie150's Avatar
    You are so correct. Sometimes people loose all sense of logic.
    What have you tried to do so far?
    bjzapp likes this.
    02-19-2014 03:45 PM
  19. baller OnHisOwn's Avatar
    i have that same problem my wifi wont turn on and says unable to scan and i tried pulling out the battery for 5 minute and it wont work
    12-31-2014 08:09 AM
  20. bjzapp's Avatar
    Make sure you didn't get in airplane mode somehow and make sure your mobile networks option is check-marked.
    If this is good I'd try press and hold the wifi button until it brings up your list(if any). If there are any listed, forget them all then try a rescan or possible reboot.
    01-02-2015 05:46 PM
  21. kagnew7's Avatar
    Believe it or not, for the Galaxy Note II it took banging the back of the device. I check several forums for a couple of hours and this was the solution. Factory resets will not fix it.
    03-13-2016 09:50 AM
  22. reduced2ash's Avatar
    Gtnunit, i have the same probloem with the wifi, but how am i supposed to download something if i cant get wifi?
    07-27-2016 10:23 AM
  23. reduced2ash's Avatar
    try using WPS push button. go to settings, got to wifi, go to more, and select WPS push button. it lets you connect to the wifi by pressing a button on your router.
    07-27-2016 10:26 AM
  24. Bagas Ajie's Avatar
    Try to flashing with stock firmware
    12-24-2016 12:06 PM
