- 06-23-2012, 01:18 PM
Thread Author #1
Wifi won't turn on or scan
I don't know what happen but after having my VM Optimus for over a year all of a sudden my wifi went kaput. In the settings>wireless and network settings the turn on wifi box is always unchecked. I'll tap it to check it. I then tap Wi-Fi settings. Before there was always a list of networks that I've either previously connected to. Now they've all mysteriously disappeared. The phone will try to scan for networks but after awhile a message will appear unable to scan for networks. The phone is stock version (no rooting, roms, whatever) with Froyo 2.2.2
- 06-25-2012, 11:08 PM #2
Re: Wifi won't turn on or scan
Try downloading a WiFi app from Play?
Sorry I can't help more :P - 06-26-2012, 03:53 PM
Thread Author #3
- 06-26-2012, 04:30 PM #4
- 06-26-2012, 05:08 PM #5
- 06-27-2012, 05:14 PM #6
- 06-30-2012, 02:25 PM
Thread Author #7
Thanks to those who responded.
Droidmyme, the phone was purchased new directly fro VM.
Kalaniboy, does a factory reset mean I'll lose everything such as settings, bookmarks, my current position in Angry Birds, etc?
Gtnunit, I did download and try Fxr Wifi with no success. - 06-30-2012, 02:36 PM #8
- 07-01-2012, 10:41 AM #9Sent via my ZV5 VMOV(ns)
- 12-14-2012, 05:49 PM #10
Re: Wifi turned on but it automatically turned off in seconds.
hello, i have a problem with my wifi connection on my galaxy k phone. i was browsing the net when the battery went empty.
i replaced the battery and turned my phone on again. But i wasn't able to use the wifi anymore,it automatically turned off in seconds after i have it turned on,and no more previous wifi spots displayed below. what is wrong with my cellphone?please help how to fix the wifi issue. aside from the wifi problem.everything is okay with my phone.thank you. claire
- 12-14-2012, 05:50 PM #11
i replaced the battery and turned my phone on again. But i wasn't able to use the wifi anymore,it automatically turned off in seconds after i have it turned on,and no more previous wifi spots displayed below. what is wrong with my cellphone?please help how to fix the wifi issue. aside from the wifi problem.everything is okay with my phone.thank you. claire - 12-14-2012, 05:52 PM #12
Reply
