- 09-18-2012, 01:26 AM
Thread Author #1
Optimus v ESN questions
I'm going to try and word this so it doesn't break any rules. I have an optimus v and a Droid 3 global. The end result of what I'm trying to accomplish would be the Droid to be working on vms network and the over well just figure out how to pull the radio files and use it as a wifi only device. I know it is possible to accomplish this task. So my question is can someone help me out in pointing me in the right direction.
P.S. I don't consider my self a "noob" I've worked with android for over a year windows and Linux for 4+ years.
Sent from my XT862 using Android Central Forums - 09-18-2012, 05:17 AM #2
Re: Optimus v ESN questions
You'd have to keep the OV OFF or in airplane mode or they'll catch you.
- 09-18-2012, 08:14 AM
Thread Author #3
- 09-18-2012, 10:45 AM #4
Pointing you in the right direction is just a nice way of saying they will be linking you to a page on how to do it, or telling you how, and neither of those are allowed here.
--Chris [cole2kb]
"Any story about malware on any platform...without numbers is not giving you the full picture, and just might be more worried about getting your clicks than any real discussion."
Words to live by: there are always two sides to every story. - 09-18-2012, 02:01 PM
Thread Author #5
- 09-18-2012, 05:07 PM #6
Airplane mode will NOT protect you! I have read several reports of people who thought that. Trust me, it didn't work. Off with the battery pulled is what I always recommend, this gives you added safety as you never have both on at once in any form.
As for help, unless you find a guide specific to your phone,that includes an easy way (or you are willing to pay for some expensive software), sell the phone and go buy an Evo V.
It's not worth the effort, hassle, or risk. Even if it works, the only rom you will get fully working is Cm7 and MAYBE CM9, otherwise MMS will not work, be flakey or make the entire system unstable. Not to mention if Virgin does check, you can get it some trouble, and yes, THEY CAN TELL. So far they have chosen not to look deep enough. The difficult and universal method takes dozens of HOURS of frustration, and again, if it works can still be detected and will be unstable undermanymost roms.
Been there, done it, got the t-shirt, not doing it again.
Sell both phones and buy an Evo V and save yourself a lot of hassle.
Harmonia Developer for Optimus V, Optimus Elite, One V, Evo V, Evo Shift, Evo V
Donate here if you feel inclined to brighten my day. - 09-18-2012, 05:42 PM #7
- 09-18-2012, 07:04 PM #8
ESN Question
By nocaldawg in forum Motorola Droid X2Replies: 3Last Post: 09-19-2011, 11:46 PM -
Optimus V Rom question
By nixie21 in forum Optimus V Rooting, ROMs, and HacksReplies: 29Last Post: 09-11-2011, 04:29 PM -
Optimus T Random Questions
By rhino4 in forum T-Mobile Optimus TReplies: 2Last Post: 02-27-2011, 08:44 PM -
Optimus vs Hero question
By outdors21 in forum LG Optimus SReplies: 21Last Post: 02-03-2011, 03:15 PM -
Esn questions involving droidx and virgin mobile
By Aruen91 in forum Motorola X Rooting, ROMs, and HacksReplies: 1Last Post: 02-02-2011, 02:23 PM
Reply
