1. _alexkta's Avatar
    Flashed Bobzhome's iho cm 7.2 rom on my LG optumus v and it wont charge at all, I reflashed and it still wont charge, can someone help?
    11-11-2012 09:40 PM
  2. bjzapp's Avatar
    Plugged in??!! Lol
    You probably need a new USB cable.they're known to go bad.
    Is it still under warranty ? If so, you can have 1 sent to you.
    if you have to just get a temporary car charger version.
    Both wall & CPU ( or other) charging methods aren't working??
    Has nothing to do with a ROM btw
    11-12-2012 05:59 PM
  3. _alexkta's Avatar
    I tried different USB cables and even on a different battery and it still doesn't charge it, but I have a charger that charges a battery without it having to be in the phone, but still I wonder if its the rom
    11-12-2012 06:37 PM
  4. PhillipBranch's Avatar
    i doubt its the rom
    11-12-2012 07:48 PM
  5. _alexkta's Avatar
    Idk what it is then, ill try flashing another rom to see if it works
    11-12-2012 08:18 PM
  1. My phone wont turn on. Help please D; lg optimus s
    By klokateer123 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 04-25-2013, 01:51 PM
  2. My phone wont let me format the sd card, help!
    By tina_33 in forum General Help and How To
    Last Post: 01-07-2012, 01:12 AM
  3. Help! My phone won't boot!
    By BMWPower06 in forum Verizon Droid Incredible
    Last Post: 01-02-2011, 03:09 AM
  4. HELP, my phone won't boot any more..
    By danielcor in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 08-13-2010, 08:30 PM
  5. My phone wont receive calls/texts
    By blacksapphire08 in forum HTC Hero
    Last Post: 05-02-2010, 09:45 PM
