Results 1 to 9 of 9
    ZackVortex's Avatar
    Posts
    ROM
    mrg666's gb rom
    Default Phone wont mount SD card
    My phone is not mounting my SD card. I tried rebooting, taking out the SD card reboot power off put SD card in turn on, erase SD card (IT CANT EVEN DO THAT)
    I can not switch roms
    I can not erase SD card
    I can not do anything SD card related.
    Witch I don't get because I have been listening to music all day.
    Any tips on how to fix this?
    Sent from my LG-VM670 using Xparent Pink Tapatalk 2
    I love this show
  2. #2
    Default Re: Phone wont mount SD card
    I get this a lot. Just keep trying to eject and insert it into your phone until it works. Blowing on the SD card and SD mount with air might work too. Sometimes restarting the phone works too and sometimes once the sd card is inserted, in the settings you have to manually press the mount sd card option but that might just be my rom.
    I think our sd card readers on the phone are just really ty?
    anyways, GOODLUCK!
    ZackVortex's Avatar
    Posts
    ROM
    mrg666's gb rom
    is there a way i can put stock rom on the phone without a sd card so i can call vm about it
    I love this show
  4. #4
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,026 Global Posts
    ROM
    Stock
    Can you access the SD card in recovery? If so, re-flash your ROM. If not, try another SD card.
    ZackVortex's Avatar
    Posts
    ROM
    mrg666's gb rom
    Default
    Quote Originally Posted by cole2kb View Post
    No I can't. Any thing that needs an sdcard I can't use. So I would like to know if I can put it on stock o I can call VM about it.
    And I don't have another sdcard.
  6. #6
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,026 Global Posts
    ROM
    Stock
    Guarantee they will tell you to get an SD card. You can't return to stock without one. Get a cheapo on ebay or go to Walmart and grab one
    Sent from my Motorola RAZR MAXX using Tapatalk 2
    ZackVortex's Avatar
    Posts
    ROM
    mrg666's gb rom
    Now I think its the phone because I put my SD card in my grandmas phone and i formatted it. I then put the SD card in my phone and it did not work. So I reformatted it on my grandmas phone turned my phone off then put the SD card in my phone then booted in to recovery still nothing. So I came with a conclusion that its a phone problem not an SD card problem.
    I love this show
  8. #8
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,026 Global Posts
    ROM
    Stock
    How old is the phone? You might not even be under a warranty any more. Like I said, you can't flash a ROM without an SD card, unless someone smarter wants to come in here and tell you how to use ADB to link /sdcard/ to /data/cache on your phone and push the ZIP to /data/cache and flash from there.
    You can also try this: [GUIDE] Unbrick/Upgrade Optimus V [EASY] [KDZ] Doesn't mention need of an SD card but I've never followed these steps so I can't say for sure if it will work like it's supposed to or not. Do the second set of instructions.
    ZackVortex's Avatar
    Posts
    ROM
    mrg666's gb rom
    Default
    I just got this phone (a replacement) so their should not be anything wrong with it. I wonder what happened.
    But I will try the guide when I get home.
    I love this show
  1. Connect via USB, Phone keeps unmounting/mounting SD card
    By doni49 in forum General Help and How To
    Last Post: 11-09-2011, 01:26 PM
  2. Connect via USB, Phone keeps unmounting/mounting SD card
    By doni49 in forum Motorola Droid Pro
    Last Post: 10-14-2011, 11:34 AM
  3. send ringtones from phone memory to sd card??
    By dondadah88 in forum HTC Hero
    Last Post: 04-20-2010, 09:55 PM
  4. How to Mount SD Card
    By Se7enth Sinn in forum Software Development and Hacking
    Last Post: 02-04-2010, 09:16 AM
  5. How to Mount SD Card
    By Se7enth Sinn in forum Motorola Droid
    Last Post: 01-27-2010, 12:11 PM
