1. sneakysnake16's Avatar
    so i need more help after flashing a package with beats audio and amphetamines my phone was unrooted. i turned it off to restart it and now the home button only works in recovery. ive gone stock, cm7, and even ics which freezes my phone within 10 minutes. please help
    12-14-2012 01:37 PM
  2. sneakysnake16's Avatar
    by the way it was on a stock rom when i flashed amphetamines
    12-14-2012 01:41 PM
  3. AndyOpie150's Avatar
    Did you make a backup of your stock ROM in the recovery? Do you have a custom recovery? If not you will need to root with the Gordita root exploit from your computer. Then install flash_image and custom recovery. Then flash the pica07 remix kernel. If that doesn't help flash the Resurrected Bumblebee ROM.
    If you need help, just holler.
    12-15-2012 05:42 PM
  1. Home button not working
    By surfacinglove in forum Verizon Droid Incredible
    Last Post: 07-26-2016, 02:09 AM
  2. Help!!! my home button quit working
    By kristi in forum HTC EVO Shift 4G
    Last Post: 04-16-2011, 10:39 PM
  3. Hold down home button not working
    By sung3d in forum Verizon Fascinate
    Last Post: 12-30-2010, 08:28 PM
  4. Home Button Stops Working/"Network Connection Fail"
    By senegal927 in forum HTC Droid Eris
    Last Post: 03-26-2010, 10:45 AM
  5. home button not working?
    By KyleBuch in forum HTC Hero
    Last Post: 02-22-2010, 08:45 PM
