1. codyahiggins's Avatar
    Is it normal for a battery pull to discharge the battery about 25%? I had to pull my battery and I was at about 80% and when I put it back in and turned on my phone it was at about 55%. Other times I've noticed the same amount of change happen after a battery pull.
    This is a tagline, not a signature.
    06-07-2013 08:46 AM
  2. raymaane's Avatar
    That can't possibly be normal. Maybe there is problem with the indicator or even the battery
    Sent from Galaxy-Note... The 2nd One!
    06-07-2013 08:49 AM
  3. AndyOpie150's Avatar
    Stock ROM or Custom ROM?
    06-07-2013 03:36 PM
  4. codyahiggins's Avatar
    I have tthought about that because at first it shows its lost more than 30% then eventually goes up to what the percentage actually is. And yes custom ROM, MiRaGe's latest.
    06-07-2013 05:50 PM
  5. kingseanrocks's Avatar
    IV had this probably before I think it was my battery because my new battery doesn't do this
    06-07-2013 08:12 PM
  6. AndyOpie150's Avatar
    Try a fresh download and Install of the latest MiRaGe.
    Don't install a battery saver app, just turn everything off including the activate app. Install Periodic Auto Sync. Set to every 4 hours for 1 minute.
    Turn things on when needed, off when not.
    Periodic Auto Sync: http://forums.androidcentral.com/sho....php?p=2837343
    06-07-2013 09:40 PM
  7. _alexkta's Avatar
    http://forums.androidcentral.com/sho....php?p=1786911
    Yea its normal Jerry Script explains why in that post its not really a rom issue.
    Sent from my VM670 using Tapatalk 4 Beta
    06-08-2013 02:48 AM
  8. AndyOpie150's Avatar
    The kernel is part of the ROM. So it would be a ROM issue.
    Probably a corruption in the ROM causing the kernel panic, hence my suggestion.
    06-08-2013 05:36 AM
  1. Replies: 28
    Last Post: 03-27-2013, 12:32 AM
  2. pulled battery out during fixing permissions, now wont boot
    By reian in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 07-31-2012, 06:26 PM
  3. resetting gnex without pulling battery
    By ZachDasher in forum Verizon Galaxy Nexus
    Last Post: 01-17-2012, 04:43 PM
  4. Phone went complete dead had to pull battery
    By jtalker1965 in forum Droid Bionic
    Last Post: 10-15-2011, 01:03 AM
  5. Manually Turn Phone Off, then Must Pull Battery to Turn On Again
    By djshack#AC in forum Sprint Nexus S 4G
    Last Post: 06-12-2011, 10:23 AM
