Thanks andy, that is how i wipe and format, but i will add obijohns wiper. I used cwm touch recovery last time i flashed this and it worked fine after unmounting cache before wiping.
I found this last night
CyanMobile help, requests, and general info - xda-developers this is for the HTC EVO but it has all the exact same settings as this rom. My point being that it has a native apps to sd-ext built in you just have to set it up before installing your apps and the apps that come with the rom can be set manually after setup.
there is a built in a2sd but needs to be setup. 1. Settings-- development -- check mount SD on boot and enable download on SD.
2. Reboot
3. Settings -- applications -- preferred install location -- sdext
4. Settings -- cyanmobile settings -- check allow application moving
5. Select install location and choose sd-ext
6. Now reboot
From now on all apps will automatically be on sdext.
You can go into settings -- application -- manage applications If everything was done correctly then you will have an option to move to sdcard and move to sd-ext/phone.
Now, my problem is i never partitioned a SD card.
Questions : I know you said that i could partition and format using zengarden recovery, but if i do that won't it wipe my SD card.
Will i have to back the SD card up?
Would it be worth doing only a 2 gb card? If so, how would i set it up?
Really sorry for all the questions, but i searched and there really is no guide that i could find on doing it without a PC.
Also, what happens when i go to restore a backup of a MiRaGe rom?
I would greatly appreciate if you could shed some light on this, again sorry for all the questions!
Thanks
