Can any one help me out here? I have a new 8gb card coming. Thank you.
Edit: What partition is the best?
Put the card into your phone and go into settings > more > storage and erase SD card
Sent from my Galaxy S4 running SlimKat 4.4.2
Thanks. But I guess I'm referring more to what partition option is the best.
FAT32 is what is used for the phone. This is a default format and what is needed to see/transfer files in a Windows OS.
The only time this will change is if you need to create a seperate partition for use with a rooted phone and Link2SD. Stock ROM and Custom Froyo ROMs need the partition to be formatted to FAT32. Pretty much all Custom Gingerbread ROMs and up require the partition to be formatted to ext.4.
Does the Optimus line even support 64-128gb cards
Sent from my XT907 using Tapatalk
What works on an F3 might not work on the V.
I'm pretty sure the V is only capable of using up to a 32GB. I think that info is in user manual.
