1. Lions2's Avatar
    So I was trying to flash an OptiS ROM on the OV. Thekraven's cm10.2 pacrom. And when I clicked the ROM to flash in CWM, It showed me ''get.prop LS_670''
    and lots of other build.prop codes, and then it aborted the installation. What happened, and how can I fix it? Is it because I don't have an OptiS? And I thought OptiS ROMs can be flashed onto the OV...
    Set from my SlimBean VM670
    05-29-2014 10:05 PM
  2. ThatGuyLurkin's Avatar
    That's all in the script when flashing.
    You can edit yourself, but probably won't know how so I'll take a look at it.
    It's been awhile since I messed with the Optimus V, so I don't remember if you can do a workaround with the recovery.
    Sent from my Nexus 5 using Tapatalk
    05-30-2014 01:44 AM
  1. M7 not viewing .mov extensions
    By JM2032 in forum Sprint HTC One
    Last Post: 05-29-2014, 06:13 PM
  2. Backing Not Flush With Surface
    By uhisthisonetaken in forum Samsung Galaxy Note Pro 12.2
    Last Post: 05-29-2014, 05:59 PM
  3. Ringtones not working
    By eric002 in forum Moto X (2013)
    Last Post: 05-29-2014, 02:09 PM
