How do I add this fix? sprint rom vm phone mms
Gutterball
45
3
I got this fix about using sprint roms on virgin mobile phones this is supposed to fix mms issues!
This is from user querty1 over in the optimus s section
"I'm going to guess MMS isn't working; I don't really care. This can be fixed, though, the VM MMSC is: http://mmsc.vmobl.com:8088/mms (MMS proxy: 205.239.233.136:81 )"
How do I change these settings on the phone?
Franzferdinan51
152
3
i dont think you can but then agin im not super pro either
the reason you cannot do this is because MMS.apk has VM's code Hard coded and cannot be swapped over their is sprint roms in the middle of being ported most famously CM7 in the works i have it on my phone
just use email in the mean time wont be too long
thtknt
