How do i UnRoot My LG Optimus V
carlitoperez
you can do pretty much everything you can do with any other rooted phone with this one. rom manager won't work because there are no real public roms available for the phone. just grab the ones off here, they all work perfectly.
fchs
16
ya cool but i am worry about my VM staff... what if i do upload to 2.3 something new and i can't use my phone anymore... i am paying for it.. what if that remove the VM then phone is no use na
fchs
16
ok now i know how to do...
liaibo101:- IS their a way to unroot the phone if you dont have a custom Rom or recovery one it - yes just open SuperOneClick and click unroot
or
You can simply do it manually using Root Explorer. delete followings AS ROOT USER and reboot. that's all!
1. /data/data/com.noshufou.android.su
2. /system/app/superuser.apk
3. /system/bin/su & busybox
Also, it can be done via adb connection.
adb shell
$ su
# mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
# rm -r /data/data/com.noshufou.android.su
# rm /system/app/superuser.apk
# rm /system/bin/su
# rm /system/bin/busybox
# reboot
Nanran21
