Anyone experiencing major delays with text messages?
Desmock, Just chill....
This is VM's "TIP" for us to get our 3G working again as it is on their facebook page...
Virgin Mobile USA
Hey guys, we've noticed some of you have been experiencing 3G web issues on your Virgin Mobile Optimus V phones. Below are some troubleshooting tips on how to reset your phone so you'll be good as new. If you need more assistance, email our social care team at VMUsocialcare@sprint.com.
1. Verify that Data services are enabled on the device (For LG OptimusV only)
a. From home screen
b. Hit Menu button
c. Select settings
d. Select Wireless and Networks
e. Select Mobile Networks
f. Enable Mobile networks.
g. Hit home screen
h. Try and browse the web.
3. When you're connecting to the web, what URL appears on address bar?
a. If it?s something other than Prepaid Cell Phone Service and Pay as You Go | Virgin Mobile or Virgin Wap then: (Works for both Samsung Intercept and LG OptimusV)
b. From the home screen
c. Select the web browser
d. From within the browser select the menu button
e. Select More
f. Select Settings
g. Scroll to Clear cache
h. Clear Cache
i. Hit OK
j. Select Clear History
k. Select OK.
l. Scroll to Clear all Cookie data
m. Select OK.
Do not know how this is supposed to help, but I guess they gave it a try? lol
This does nothing to address the problem. They are telling you to clear browser cookies.
Supposedly data was down to upgrade my data is faster today and no drops.
My data hasn't dropped at all today but speeds are pretty much the same.
Sent from my LG Optimus V using Tapatalk
?Customers with 3G-capable cellphones and modems will find that they can now benefit from higher data speeds following the upgrade of Virgin Mobile?s underlying cellular network,? Virgin Mobile says in a statement.
So according to the VM coverage map, where im normally at is pretty much 100% covered. Sometimes at work (metal roofing, concrete walls) i lose signal. This also happens at a friend's house where 3g kinda sucks (even for them on ATT). However whats confusing is that when i lose data and webpages and apps wont load anymore, if i toggle airplane mode (at least once, sometimes more than once) i can get the data connection back. Also, the 3g symbol and the arrows never go away, even when i lose data access the symbol (and activity) remain.
What throws me off is that when i do get the connection back in those locations, i get a decent speed. 600kb/s this last time i got it back. So its not like i have a really weak signal thats getting poor speed/bandwidth. What gives?
currently OC'd to 806mhz stable, Stock VM Rom+ Xionia kernel (revolution red).
A good app for someone to make (*wink wink*), would be one that monitors the wifi and/or G3 and runs certain actions if connectivity is lost to, for example, google.com. Something like the stay alive script in dd-wrt. It can toggle the 3G and other apps that need it after a connection loss. I've noticed that sipdroid does not like the handoff from wifi to 3G. There is a good min or two where it is confused. I can manually cause it to reconnect by opening the program interface for a second.
