Results 1 to 19 of 19
    Default Updating Swype on Optimus V
    So I just read that the Swype beta was updated. However, since the Optimus came with Swype pre-installed I'm wondering if I should update or leave it as is?
    I'm in the beta (or is it open by now?) so I can download the update. Should I?
    Thanks.
  2. #2
    dan6681's Avatar
    Posts
    Global Posts
    13 Global Posts
    Default
    Quote Originally Posted by rubejb View Post
    Thanks.
    You have to root your device.
    Then there are directions that seem to be working for people.
  3. #3
    Default
    This doesn't make any sense. We can update other pre-installed apps from the Market just fine (for example WHERE was just recently updated). Seems like an issue SWYPE needs to address, not Virgin.
  4. #4
    Default
    Quote Originally Posted by Bigtuna00 View Post
    I believe the issue is that the Beta version isn't in the market so you won't see the update.
  5. #5
    joshua.worth's Avatar
    Android Guru
    Posts
    Global Posts
    807 Global Posts
    ROM
    Android 4.1.1 Jelly Belly
    Default
    I'm on the latest asopmod/cmod7 (Gingerbread) I just got the newest beta that's back open personally though I like the Gingerbread keyboard better than any other the keys are smaller and more spaced which has been a lot better from my experience between the stock froyo keyboard and this
  6. #6
    Default
    I have my phone rooted.. and it's pretty simple. Get Titanium backup.. if you want make a backup, I didn't. Uninstall Swype through Titanium, then install the updated beta. Bam, and no more annoying window every single time you hit a word that's the one next down on the list, woo!
    Thanked by 2:
  7. #7
    Default
    Quote Originally Posted by Godbilla View Post
    ...and no more annoying window every single time you hit a word that's the one next down on the list, woo!
    My goodness, I hate that window!
  8. Thread Author  Thread Author    #8
    Default
    I'm rooted as well, so install should be easy, but I had a thought. I know the old Swype beta had a time limit, and after it expired you had to update or it wouldn't work.
    Is this still the case with the beta? If so, I'd rather just stick with the preinstalled version.
  9. #9
    humanakeo's Avatar
    Posts
    ROM
    RodimusRom v1.2.2/Xionia
    Default
    it didnt say we had a time limit..... but instead of removing the old swype off your phone just rename it instead of deleting so youd have it just in case
  10. #10
    Default
    Quote Originally Posted by humanakeo View Post
    How do you do that? And would that mean you can choose between both versions of Swype from the Input Method menu?
  11. #11
    Default
    Talking about that annoying window...you can turn it off in the settings or make it appear less often.
    Customize whether Swype displays the Word Choice window by setting the 'Word Choice Window' slider in Swype Advanced Settings.
    • To see the Word Choice Window less frequently, set the slider towards the left.
    • If you are very distracted by the Word Choice window popping up, you can set the slider all the way to the left so that the Word Choice Window will never be shown automatically.
    • To see the Word Choice Window more frequently, if you prefer to select the correct word right away as each word is entered, set the slider further towards the right.
      Try the default setting – you will find that the Word Choice Window usually pops up when you need it to. Remember that even when the Word Choice Window pops up, if you start Swyping a word, the window will be dismissed and the default word (at the top) will be output.
    Thanked by:
  12. #12
    Default
    Quote Originally Posted by investor22 View Post
    With this knowledge, is it worth upgrading to Swype beta still? Is there any noticeable difference in how well it guesses words?
  13. #13
    Default
    I don't think Godbilla was referring to the "Word Choice Window". I believe he was referring to the "Hidden Word Tip" popup. (That's the window that drives me crazy!)
    In the version of Swype that is installed on the Optimus V, the "Hidden Word Tip" popup cannot be disabled. But the Swype Beta maintenance update on 3/10/2011 added a feature to only display that popup once.
    Quote Originally Posted by http://beta.swype.com/
    Major bug fixes, including setting the "Hidden Word Tip" popup to only appear once per installation, and allowing contact names to be permanently removed from the user dictionary
    Attached Thumbnails Attached Thumbnails Updating Swype on Optimus V-hiddenword.jpg
  14. #14
    Default
    Quote Originally Posted by davidh44 View Post
    Guesses words pretty good. The thing is, I found the stock version of Swype on the Optimus V to deteriorate drastically. After rooting my phone, uninstalling it, signing up for the beta and installing the beta version, bugs are fixed and it seems to be somewhat more accurate. Test it out.
  15. #15
    LeslieAnn's Avatar
    AC Forums Android Developer
    Posts
    ROM
    Harmonia 3
    Default
    You can add words to the dictionary to help it guess more accurately.
    For me "is" often became "ios", but putting is in the dictionary corrected it's preference.
    Harmonia Developer for Optimus V, Optimus Elite, One V, Evo V, Evo Shift, Evo V
    Donate here if you feel inclined to brighten my day.
  16. #16
    Default
    I uninstalled the stock Swype thru Titanium Backup and installed the latest Swype beta last night. This morning, I was greeted with the message:
    Sorry! The application Swype (process com.swype.android.inputmethod) has stopped unexpectedly. Please try again.
    Force close
    Hopefully this won't be a common occurance or it will be annoying. iHas this happened to anyone else's LG Optimus V with the Swype beta?
    EDIT: I power-cycled my phone and I started getting that error message repeatedly. I'm following the instructions in this thread to see if that will resolve the issue:
  17. #17
    Default
    I got the same message. After taking the advice from a fellow from the Swype forums, I got it working. All I did was reinstall the newest version. Not sure why, but it worked for me and a few other folks. Make sure you uninstall it, then reinstall. Should work fine after that.
  18. #18
    Default
    Quote Originally Posted by joshua.worth View Post
    Thanks So much! I was getting so infuriated with that damn "hidden word" tip I wanted to throw the phone at the wall at times. I don't know why LG hasn't updated the version of Swype included with the phone. At least there is finally a workaround.
  19. #19
    bigsupersquid's Avatar
    o_O
    Posts
    ROM
    PAC ROM+Raspbian wheezy
    Default
    Quote Originally Posted by SagaciousB View Post
    as far as I've read around, LG hasn't updated squat for the VM optimus. The sprint version has had several firmware updates, though.
    I tried removing the stock swype in froyo and downloading the beta, but it refused to install. Just as well, I like gingerbread better anyway.
    too bad about the word choice window not being optional in swype beta 3, I sure don't like being unable to turn it off. other than that, I haven't noticed much difference in the beta versions.
    I'm about to roll back to the 2.x beta I downloaded last, from my nandroid backup, to get rid of the extra screen-blocking popup for word choice.
    the beta 3 still pops up the hidden word tip at me, as well. ugh.
