Phone bricked .CAB flash problem
mastajeff
9
Ok well I went to go restore my phone to factory and forgot that I couldnt it would cause problems. I did that because for some reason it wasnt letting me install a custom recovery. Now all it does it get stuck at the LG logo on boot and stays there. I cant access recovery.
So far I got the .CAB and I am trying to flash it using KP500-Utils-EN tool. IT extracts the cab but it gets a error saying it needs more information. I tryed the method of renaming the CAB to KDZ and using the KDZ flash tool but it fails on extract. Any tips? I called virgin and a free replacement is on its way but i would like to fix it..
Stop! Don't flash the cab!
Read: http://forum.androidcentral.com/optimus-v/66065-mobile-data-issue-after-wrong-sw-update.html
http://forum.androidcentral.com/optimus-v/57485-how-root-lg-optimus-v.html
http://forum.androidcentral.com/optimus-v/58106-how-return-your-phone-stock-mostly.html
Yeah still getting this problem :/
Code:
17:07:42 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
17:07:42 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
17:07:42 : Start Date : 2011-03-23 17:07:42
17:07:42 : -------- Buyer Test mode ---------
17:07:42 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
17:07:42 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
17:07:42 : *****CheckOS Start********
17:07:42 : Microsoft_Windows_Vista Home Edition_
17:07:42 : *****CheckPCSyncPrograms Start*****
17:07:42 : PCSyncPrograms Not Found
17:07:42 : SetEmerModeAT()
17:07:42 : _IsConnectedPhone Call
17:07:50 : _IsConnectedPhone(2)
17:07:50 : 0 - NotConnected.
17:07:50 : 1 - Normal connect success
17:07:50 : 2 - Emergency connect success
17:08:13 : Checking the connection with the cell phone...
17:08:13 : dwWaitResetTime(40000 ms)
17:08:14 : Phone Mode(2)
17:08:14 : *****GetPhoneType Start*****
17:08:14 : Phone Type : CDMA
17:08:14 : *****Start GetPreviousStep*****
17:08:14 : [011,700,147,062,092]Updating is not possible any longer due to a fatal error.\n\n[009,400,102,102,102]Disconnect from and connect the cable into your phone again and remove \nand install the battery and press the [009,700,102,102,102]'Restart'[009,400,102,102,102] button. This will resume the \nupgrade.\n\n\n\n\n\n\n\n\n\n\n\n\nPress the [009,700,102,102,102]Quit[009,400,102,102,102] button to stop the update.
17:08:14 : _GetPreviousStep(dwStep:0x4)
17:08:14 : *****GetPhoneBinaryVersion Start*****
17:08:14 : CSE mode -> Version Replace
17:08:14 : *****Get ESN / IMEI / MEID Start*****
17:08:15 : *****GetPhoneNumber Start*****
17:08:15 : Phone Number : 00000000000
17:08:16 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : 00000000000, Model :
17:08:16 : _GetAuthMark : wAuthMark(65535)
17:08:16 : Wait 3Sec
17:08:22 : _SetAuthMark Ok : wAuthMark(32028), PhoneMode(2)
17:08:22 : *****CheckPCSyncPrograms Start*****
17:08:22 : PCSyncPrograms Not Found
17:08:23 : CLGMobileHttp Class ?Ҹ????.
17:08:23 : CLGMobileHttp Class ?Ҹ?...
17:08:23 : ****************CheckAndDownload********************
17:08:23 : ******Extract Start VM670zv4.cab*****
17:08:23 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
17:08:26 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\VM670ZV4_13.S4_13.P61007.wdb\n
17:08:26 : WDB(or DZ) FullPath(C:\ProgramData\LGMOBILEAX\Phone\\VM670ZV4_13.S4_13.P61007.wdb)
17:08:26 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\VM670ZV4_13.S4_13.P61007.wdh\n
17:08:26 : Necessary information not found\n\nPlease contact via http://www.lgservice.com[009,400,102,102,102].
17:08:26 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
17:08:27 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
17:08:27 : CLGMobileHttp Class ?Ҹ????.
17:08:27 : CLGMobileHttp Class ?Ҹ?...
17:08:27 : Page_Error ?κ??Դϴ?
17:08:27 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
Why would you even flash that cab to an android phone in the first place? Try using fastboot to recover.
Because it cant do anything.. cant go into recovery.. cant get to it through ADB.. if I try going to recovery it just loads a blank black screen. How do i use fastboot? the only thing i can get in to is emergency mode
Code:
same thing happens to me i been trying for weeks and cant get it to work
I read somewhere around here about someone who used files for the optimus s to recover with emergency mode. They got it up and working but Mobile Data was broken.
IHO Unofficial CM7. 2
BACKside IHO 12212011
Do NOT try this until you have all the facts.
Yes, they got it working, and I think even data, however, it took a very long time and a ton of effort.
I'll agree with Leslie since she has way more experience then me but still think it's relevant if you really can't do anything else with the phone. Wish I could find the thread to link tho. You can't read too much when it comes to these things
Look at the sticky in the all things root guide, should be able to get it from sammyz. Pm him about zv4, unless your fine with zv5.
Have you tried it? Sammyz rebuild the non working firmware cabs. The one you used probably was one download from somewhere else, only his actually flash.
Tfunz
