1. Oversteer's Avatar
    So i'm new to droids and I keep having trouble with the internal storage. I haven't downloaded that many apps but I keep getting the warning, despite transferring every app I can to the sd. So is the internal RAM That small? What do I do to keep my phone working? There must be a workaround for this as the storage runs out so quickly.
    Thanks to all for any help...
    04-03-2011 12:30 AM
  2. LeslieAnn's Avatar
    All of the workarounds require you to root your phone.
    04-03-2011 12:45 AM
  3. scootincivic's Avatar
    Do a bit of reading here on "link2sd" and rooting and all your issues will go away~
    Sent from my Optimus V vai Tapatalk
    04-03-2011 12:56 AM
  4. Oversteer's Avatar
    Thanks for the info. I've read a little about rooting but before I go any further, is rooting possible using a Mac? My computers are macs and wondering if there is a way to root, either directly or via some software?
    Thanks
    04-03-2011 06:53 PM
  5. denshigomi's Avatar
    Thanks
    It should be fine. Just install the Android SDK and then run a root exploit in ADB.
    04-03-2011 07:35 PM
  6. lizm's Avatar
    Do you have your music and everything else on your SD card?
    I am aware that i have a lot less storage on the internal memory of this phone than I did on my incredible, but i still have 30 or so apps on here, a handful on SD, and space to spare.
    Maybe one/some is generating a ton of data, images, maps, something?
    04-04-2011 05:52 PM
  7. Oversteer's Avatar
    it's not the sd card--it's the phones internal storage. sd card has tons of space left and now i've even installed an 8 GB card. also, i've moved everything possible to the sd card but still i'm on the edge.
    gonna be rooting soon.
    so if i understand this correctly, once rooted, my phone will use a partition on the sd card as internal storage? if this is correct, how much of my 8 GB card should i partition for the ROM or internal storage?
    04-07-2011 02:26 PM
  8. JerryScript's Avatar
    No, rooting will only give you the permissions to make any changes you want.
    Once rooted, you download app2sd from the market, and it will give you the option to install apps to the SDcard.
    Remember, if an app has a widget, you have to leave it on the phone's internal memory to be able to use the widget. You can still use the app regardless of where it's stored, but widgets must be on internal storage.
    04-07-2011 02:30 PM
  9. Mpizgatti's Avatar
    Something I did recently was follow this guide:
    Force apps to move to the SD card on Froyo AndroidBoss
    There are some explained across the web as well and probably on this forum that might be easier explained for you, I looked at a few but they all basically have the same method. It allows you to force more to install on the Sd and move some that won't. You can reverse it and it doesn't require a root.
    04-07-2011 04:57 PM
  10. Oversteer's Avatar
    A couple things:
    1) Is there a way to move the storage folders to the sd, as in all the emails, contacts, texts, etc? They appear to be causing trouble even though they are relatively small.
    2) Also, I am unique to most of this because I use macs for my computers and have limited knowledge of pc basics, and of course most of the rooting instructions assume pc computers. So is anyone else using apple computers to root? I know it's possible but the process it's different and I can't find step by step instructions.
    Thanks
    04-07-2011 11:33 PM
  11. Eollie's Avatar
    Help rooting via a mac I have no clue.
    However once you do dont bother with the apps that move things to your sdcard.
    Check this out, data2ext it will create a partition on your sdcard and after running the script and adb commands move everything to the sd card. BUT it makes the phone think its still the internal storage therefor apps with widgets will still work.
    I created the biggest partition available which was 1gb and I dont foresee me filling that anytime soon.
    04-08-2011 02:22 AM
  12. zires's Avatar
    Hey,
    What worked for me without partitioning etc was to use Move2SD enabler paired with App2SD Pro. I have 50+ MB on my internal memory.
    04-08-2011 01:30 PM
  13. Eollie's Avatar
    Hey,
    Thats awesome but think about having 900mb of free space..
    04-08-2011 03:15 PM
  14. zires's Avatar
    900mb of free space where?
    04-08-2011 03:58 PM
  15. Eollie's Avatar
    follow the guide I linked to.
    Read it several times before jumping in.
    What it does is create the partition on your sd card and then trick the phone into thinking its actually the built in phone memory.
    04-08-2011 05:03 PM
  16. yhide's Avatar
    my phone is fixed without having to root the phone.
    YI was constantly getting the low space error. subsequently some apps wouldn't install. I hard reset the phone and formatted the sd card. I have plenty of space now and no error messages. between app brain and the market I got everything back but it took a while
    Opal Gypsy likes this.
    04-09-2011 10:49 AM
  17. 1158pm's Avatar
    I just ran into the same prob. I found lots of cashe files, old data files, and stuff leftover from apps I uninstalled. Get a file manager, I use Adobe, and purge them. I was astonished by how much memory was being taken. Hope that helps.
    04-14-2011 05:21 PM
  18. Eollie's Avatar
    Ive noticed on my sdcard if a app creates a folder the folder doesnt get deleted off the sdcard. Kinda pisses me off because you should get the option to completely remove all data when uninstalling apps.
    04-14-2011 06:17 PM
  19. zires's Avatar
    @Eollie,
    Have you tried sd maid? Free on the android market. For rooted phones.
    04-15-2011 11:39 AM
  20. Eollie's Avatar
    @Eollie,
    Ive seen those type of apps. Normally I just delete them via mounting to my pc and double checking them before deleting.
    It would be nice if app devs could/would code in that if the application is removed so is the folder it created.
    04-15-2011 12:53 PM
  21. Delphis's Avatar
    Yes, you can move items in /data/data to an ext partition as well as all the apps and their symbol cache files. I wrotea thread about it on this forum. I have made a script to move items in /data/data very easily. Once I have added some 'safety' features I will release it
    04-15-2011 07:55 PM
  22. 1158pm's Avatar
    I second that motion. Devs please take this into consideration. It would be a great help to us all.
    Sent from my VM670 using Tapatalk
    04-17-2011 07:05 AM
  23. LeslieAnn's Avatar
    Exactly why you haven't seen this in roms yet.
    The potential for a user messing it up is quite high. It's fine for those who know what they are doing somewhat, but look around at how many have trouble with recoveries and rooting. It's just a huge amount of support most don't want to deal with.
    Most of us do this in our spare time, just fooling around. You have no idea the number of requests for special builds and features we get, not to mention pm's asking for help. I don't want to be responsible for someone wiping out their entire phone. Or worse, bricking it due to a bad partition. Mmmark111 already bricked his by messing with partitions, now imagine a noob trying to do something like he was doing.
    If you want something like that, great, but I already looked into it for Aphrodite and from everything I have seen, there is no way I would implement that at rom level.IF it can be done more safely and easily, yes I would give it a go, but it woudl have to be dead simple and reliable as all heck.
    04-17-2011 05:12 PM
  24. Eollie's Avatar
    ^^^^^THIS^^^^
    Somethings just dont need to be in the rom.
    If you want the function on your phone take the time to read and understand how to do it. But please please lets stop hounding the devs to include every little thing in the roms. If you give too many options and or abilities you run in to doing nothing but troubleshooting. Let the things like this be troubleshooted by the people creating it. And not a rom dev that could be sitting in the sun with a cold beverage after a release instead of troubleshooting why the newest release is not working right and the community is rumbling about wanting things fixed.
    04-17-2011 07:17 PM
  25. cpshelley2's Avatar
    ^^^^^THIS^^^^
    hear, hear Eollie!! my thoughts exactly!!
    04-17-2011 09:33 PM
