Results 1 to 14 of 14
    bb6h22lude's Avatar
    Posts
    Carrier
    AOSPCMOD OV 6/1/11
    Default Help! Stock Rom
    First time posting something on this. I love this forum. I am currently on asopcmod 2.3 20110403. I need to get back to the stock rom. I have my reasons. I just don't know how to. I don't know where to find the stock 2.2 rom. Could someone please help me? Thank you.
  2. #2
    Default
    How to: Return your Optimus V to Stock(Tested working)
    IDK which recovery you are using but you may need to switch it.
    bb6h22lude's Avatar
    Posts
    Carrier
    AOSPCMOD OV 6/1/11
    Default
    I am on clockwordmod 3.0.0.6 i think or 3.0.6. Do i just need to flash the rom? If so where can i find it? I've looked on google and only found stock rom with experimental xonia kernel
  4. #4
    Default
    You didn't do a backup first?
    Sent from my LG Optimus V
    bb6h22lude's Avatar
    Posts
    Carrier
    AOSPCMOD OV 6/1/11
    Default
    No, when i rooted and flashed my phone i didnt know about backup and restoring. So is there no other way? Is there a stock rom on the internet? I was having trouble with my 3g and i called vm and they had me enter ##847448# or something and it wouldnt do anything. i just want my stock rom because i cant receive mms and it takes ten minutes to send a mms if it even does send. I'll just wait for the gingerbread update when they release it for the optimus ones.
  6. #6
    Default
    Quote Originally Posted by bb6h22lude View Post
    Probably your best bet would be Xionia ROM
  7. #7
    Default
    I gave you the link on post 2, it has the stock rom and recovery, but you may need to flash a different recovery is what I am saying.
    I don't think that version cwm can flash back to stock without an error.
    This recovery should work fine to get back to stock.
    Custom Recovery Optimus V - Android Forums
  8. Thread Author  Thread Author    #8
    bb6h22lude's Avatar
    Posts
    Carrier
    AOSPCMOD OV 6/1/11
    Default
    Ok will try it. Do you know if i'll be able to get to the activation menu by pressing those keys i was saying? Just in case i have trouble and have to call virgin mobile and they tell me do to that. Last time i entered that nothing happened. lol and they started to get suspicious lol.
  9. #9
    Eollie's Avatar
    Posts
    Global Posts
    1,575 Global Posts
    Carrier
    Some arrogant a-holes
    Default
    If it is a true stock rom yes.
    IIRC its even possible on the stock+xionia kernel romm.
    If you like the gingerbread roms flash the stock one. make a nanadroid backup. Then flash the custom rom you like. When you need to use the input codes just do a recover to the nanadroid and do what you need and then recover to your custom.
  10. #10
    xabbott's Avatar
    Posts
    Global Posts
    22 Global Posts
    Carrier
    Harmonia 1.5E
    Default
    None of the gingerbread roms have functional MMS with VM at this time.
  11. #11
  12. Thread Author  Thread Author    #12
    bb6h22lude's Avatar
    Posts
    Carrier
    AOSPCMOD OV 6/1/11
    Default
    Quote Originally Posted by DestUndead View Post
    i have a stock rom with just root access
    https://docs.google.com/leaf?id=0B1_...YmE3MDdh&hl=en
    Thank you im downloading it right now. Do you know if i can use cwm 3.0.0.6?
  13. #13
    Eollie's Avatar
    Posts
    Global Posts
    1,575 Global Posts
    Carrier
    Default
    Quote Originally Posted by xabbott View Post
    Not true you can send mms just cant receive.
  14. #14
    Default
    I would not use it. I don't believe the clockwork mod works correctly on the v. I used a different recovery. And aosp rom now has mms guys. Please thank and donate to him. He has done the impossible. For a sick looken ui I suggest open home 6 full with the gingerbread theme.
    Sent from my VM670 using Tapatalk
Tags for this Thread
