I cant figure out how to make a theme for the theme chooser on aosp CM7mod the 4/15 release i need help bigtime a walktrough wud be gr8 thanks ahead of time
If you read the thread in the forums linked to from UOT, you will notice it is not compatible with ROMs containing odex files, which at this time aospCM7 does.
If/when this ROM gets deodexed, you will then be able to use UOT.
Note-Hopefully I'm wrong and someone else will post a way to use it as is.
Are there any odex files in this ROM? I checked on my phone and there are none in system/app, data/app or system/framework folders where the usual suspects reside.
