Results 1 to 4 of 4
    broknbottle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Phone stuck in clockwork recovery loop
    I had my phone flashed with clockwork recovery and CM7 but after using an external antenna the internal antenna on my Optimus V stopped working. I was trying to make it as stock as possible so I could exchange since that's what the VM rep said I should do. In the process I flashed a stock ROM and ended up putting my info in so I recovered using the option under the privacy settings. I am now only able to boot to clock work recovery and I am able to obtain a adb shell. I am not able to do su and I am unsure of what I should do next.
    I appreciate any input, thanks!
  2. #2
    mmarz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Try this:
    adb shell strings /dev/mtd/mtd8
    adb shell flash_eraseall /dev/mtd/mtd8
    http://forum.androidcentral.com/848500-post18.html
  3. #3
    taptapcrash's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Tried it. But this happens:
    /sbin/sh: flash_eraseall: not found
  4. #4
    mmarz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Try installing a new recovery or reinstalling the recovery you already have. That seems to fix the issue for others in the same situation.
