1. sgtsc0rpi0n's Avatar
    Still trying to escape boot loop.
    /sbin/sh: flash_eraseall: not found
    Why am I getting this message when trying to execute:
    adb shell flash_eraseall /dev/mtd/mtd8
    06-11-2011 04:25 PM
  2. gater's Avatar
    I was in the stupid boot loop after doing a "LG Style Wipe" in recovery.
    I followed: This
    06-11-2011 04:38 PM
  3. sgtsc0rpi0n's Avatar
    my biggest problem I'm in is the only screen i can get to is ClockworkMod Recovery v3.2.0.0. I can't even get to the lg recovery screen. In fact I've never even seen it. I was messing with a custom ROM and Factory Reset through Settings>Privacy :/
    I have tried wiping everything and restarting from back-up,
    I've tried:
    adb shell strings /dev/mtd/mtd8
    I get "FACT_RESET_3"
    I get "/sbin/sh: flash_eraseall: not found"
    I'm running out of ideas
    06-11-2011 04:57 PM
  4. gater's Avatar
    Right...same here. I did the factory reset through my recovery. There is no LG Recovery Screen. Just follow the steps for fastboot.
    06-11-2011 06:06 PM
  5. JerryScript's Avatar
    Download a custom ROM file to your computer, I like aospCM7 for all the gingerbread goodies.
    aospCMod-VM670-20110601-signed.zip
    You'll need gapps to get the market working too, so download it as well
    gapps
    Once in recovery do the following:
    Connect your phone via usb, and push the custom ROM of your choosing onto your sdcard:
    adb push c:/....PATH_TO_ROM_ZIP_FILE/NAME_OF_ROM_ZIP_FILE /sdcard/NAME_OF_ROM_ZIP_FILE
    adb push c:/....PATH_TO_GAPPS_ZIP_FILE/NAME_OF_GAPPS_FILE /sdcard/NAME_OF_GAPPS_FILE
    note: there is a space before /sdcard
    Then in recovery:
    1) wipe cache
    2) under advanced, wipe dalvik cache
    3) under mounts, format boot, cache, data, and system
    4) select install zip from sdcard, then choose the ROM zip file you pushed via adb. Note-do not choose install update zip
    5) select install zip from sdcard again, this time choose the gapps zip file you pushed via adb. Note-do not choose install update zip
    5) back into the main menu of recovery, choose reboot system now
    It will take along time for your phone to reboot since it has to rebuild everything, once you get to click on the android to setup your phone, choose to setup your account later, since you don't have a physical keyboard to use at this point, just set up your google account later.
    06-11-2011 09:27 PM
