Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By bmwkeith
    Default Is it possible for Flash Player to work on the Reverb?
    Has anyone been successful in installing a working version of Adobe flash on this Phone?
    Sent from my SPH-M950 using Android Central Forums
  2. #2
    bkttk2's Avatar
    Posts
    ROM
    Stock
    Default Re: Is it possible for Flash Player to work on the Reverb?
    Quote Originally Posted by bmwkeith View Post
    Yes. Take a look at the following link:
    Hope this helps.
    Thanks, that worked great.
    bkttk2 likes this.
  4. #4
    For installing adobe flash player on Android device, you can find the proper apk on the official website of Adobe flash player.You can refer to
    If you want to know something about flash player go to this blog flash-video-player.blogspot.com
  5. #5
    Flash is not popular. Html 5 is coming.
    Sent from my HTC One X using Android Central Forums
  6. #6
    Yeah
  7. #7
    Quote Originally Posted by kizy View Post
    Yeah
    How did you do it?
    Sent from my EVO 4G LTE
  8. #8
    bkttk2's Avatar
    Posts
    ROM
    Stock
    See links near beginning of this thread.
    Good Luck!
  9. #9
    Ok, I installed it, thank you soooo much, however when I tried to use it to listen to a radio station the old message still came up. Please help. Thanks!
  10. #10
    bkttk2's Avatar
    Posts
    ROM
    Stock
    what's the link for the station?
  1. Is it possible for the Sprint screen protectors to leave a mark
    By nikeairs23 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 10-07-2011, 09:01 PM
  2. Is it normal for this phone to get very hot?
    By FatalIll in forum Virgin Mobile Optimus V
    Last Post: 05-12-2011, 09:02 PM
  3. Replies: 6
    Last Post: 10-05-2010, 09:59 PM
  4. Replies: 1
    Last Post: 07-15-2010, 08:21 AM
