1. crazycc135's Avatar
    I'm trying to log into my college's WIFI. It's protected and locked, so I type in my password and username. Then the problem starts. Sometimes it says "authentication failed" when under the wifi name it says "saved, secured" and it won't let the wifi come on. Other times it will connect and then won't stay on. I don't have a date limit on my phone and I want the wifi to stay on all the time, but it shuts itself off sometimes and then it gives me problems trying to get it back on. Any advice or instructions to keep the wifi on all the time? I turned on the wifi timer to have it on when I wake up and shut off when I go to sleep to see if it helped but it didn't. Help!
    04-10-2013 11:19 AM
  2. bkttk2's Avatar
    In wifi select advanced setting. One option allows control of wifi on and off. Select wifi on even when screen shuts off. Hope this helps.
    Sent from my SPH-M950
    04-10-2013 08:39 PM
  1. Wifi problem.
    By joec32033 in forum Verizon Droid Incredible
    Last Post: 09-13-2010, 07:02 PM
  2. wifi problems
    By Sere81 in forum Verizon Droid Incredible
    Last Post: 07-21-2010, 04:49 PM
  3. Nexus running 2.2 wifi problems!!!
    By DVNO in forum Google / HTC Nexus One
    Last Post: 06-05-2010, 12:28 AM
  4. Droid WiFi Problems
    By jlgraham in forum Motorola Droid
    Last Post: 03-30-2010, 03:02 PM
  5. Wifi Problems on Eris
    By twizler3 in forum HTC Droid Eris
    Last Post: 12-10-2009, 06:54 PM
