So I got the 7 edge sunday, got home popped it in the headset all the software asked to install etc..awesome... played with it for a bit decided to pop it out download some more stuff for it and play with it more later.
So last night go to play with it pop it in, screen turns black for a few seconds and then goes back to normal phone home page. Tried rebooting it taking it in and out again etc. It makes the noise when I pop it in and the screen goes black every time then back to home page. I went to the occulus page it had instructions for what to uninstall and then said just pop it back in and it should ask to reinstall......mine did not. So I dont know how big a problem this will be but sadly I hope big enough they fix it otherwise I might have to wait to see if I can find the apk or something to reinstall it manually so far I have not yet though....Shame cause the little I played with it, seemed pretty cool and I was looking forward to trying some more stuff out otherwise I am very happy with the phone minus the removal of the IR blaster.
