Wireless Charger For My Phone?
A
AC Question
So I have a wireless charger and a samsung galaxy S6 I think
It's the waterproof version with that funny clip on the charger port so I didn't want to have to find a pin or something to open it and got a wireless charger
I put it on the charger face down and the light on the wireless charger starts flashing, but it doesn't charge, is it because of the waterproof back?
What do I need to do to make it work?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Re: Wireless Charger For My Phone
Welcome to Android Central! You typically place the phone's back on the wireless charger, not the screen. Have you tried that?
Caboose5011
5
I have, and nothing seems to happen, I searched around and I couldn't find anything on this matter.
The light only starts flashing when I put it faced down on its screen, when I place it down on the back on the charger nothing happens.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
You said that you have a "Galaxy S6 I think." Can you clarify which exact phone you have?
Caboose5011
5
Heres what it says in the About device
Model number SM G900F
Android Version 5 0
Baseband Version G900FXXU1BOH4
Kernel Version 3 4 0 5651870 dpi SWDE2206 1
Fri Aug 21 13 53 44 KST 2015
Build Number LRX21T G900FXXU1POH9
SE For Android Status Enforcing SEPF SM G900F 50 1 0032
Fri Aug 21 13 56 07 2015
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
You don't have a case on, right? What brand of charger is it? Does the charger work fine on other devices?
Caboose5011
5
I have a case on and its the waterproof snap on one, the charger is samsung make and so is the cable, the cable charges my phone fine.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
It'd be ideal if you could test the wireless charger on another device, to make sure it's functioning correctly.
Caboose5011
5
I have just tried it on another device and it came out with the same result, I think I might have a galaxy S5, rather than an S6, is there different makes of wireless charger pads I need?
